im parting 2 built cars
mine and a friends s13
If theres something you need and dont see just ask
first up
17X8 +35 Racing Hart C2 true 3 peice wheels 4/5X114.3
235 45 17 FM901s with 90% rear tread, 40% front.
$1100
New Tomei 2-way diff, new in box. Needs open dif housing
$1100 Firm was 1700 all said and done, new
s14 Megan coilovers 9/7 sr’s very good condition.
$950 NOW $750!!! MUST SELL ASAP
s14 silvia Q’s front bumper, sits lower than stock na spec.
$250 NOW $200!!!
S14 megan type II catback 3 inch stainless
$400 NOW $350!!!
Blitz mild steel DP
$150
Megan coilover extentions for s14 (run wider or higher offset wheels)
new
$100
Brand new Megan s14 tie rods and tie rod ends.
$100 each
Custom built V mount designed for a s13 sr into a s14. Easily modified to fit s13 sr in s13, could be made to fit ka or s14 sr as well.
24x12X3 Greddy FMIC refinished, does have some damage but holds 30psi with no issues, i can pressure test if required
27.5X15.5X3 Griffin circle track Rad refinished. The same rad they use in Nascar. comes with AN fittings for bleeder and drain.
Turbo XS H-RFL BOV with aftermarket stiff spring, sounds great.
custom made outlet elbow for a t25 may also be included but i would need a stock one in exchange.
all T bolt clamps and black 4 layer reinforced couplers included.
custom coolant elbow for sr with relocated Griffin filler cap
all rad hoses and vac lines, and idel air bypass
14 inch rad fan
$1000 NOW $900 MUST SELL ASAP NOW $700!!!
Brand new complete suspension technique bushing kit F&R for s14, black
$250 NOW $225
2 225 45 17 tires, i dont know what brand, to lazy to go look , good to burn 30ish tread left
$20 each NOW $30 for the pair!!!
2 235 45 17 tires, i dont know what brand, to lazy to go look, good to burn 30ish tread left
Misc 2.5 inch scilencer with flanges, doesnt fit anything stock
$40 NOW $25!!!
New Miata battery, very compact, good for a FMIC setup with out battery relocation.
pretty powerful for its size
used to crank my car over once.
$125
1 s14 silvia emblem, i may have another somewhere in the garage, blueygreen kinda. Like my car
$25 each
Custom bumper caps for s14 never installed
$100 [red=color]NOW $75 MUST SELL ASAP
Monster R33 GTR Skyline brakes, i inch larger that Z32
bolt up to 4 or 5 bolt
includes good front rotors, PBR pads f&r, and stainless lines on front
painted gold.
Make car stop fast
shown on s14 stock wheels and 16 inch advan seinna G2 wheels
$700 NOW 550 MUST SELL ASAP
Alpine S10 sub and amp in box
i have another sub if you want 2
$200 for 1 sub and amp, $250 for both
Carbon fiber overlayed rear taillight center section for s14, reverse lights do shin through.
$100 NOW $50 MUST SELL ASAP
Nardi steering wheel with megan quick release and HKB hub and silvia horn button
$300 NOW $250 MUST SELL ASAP
5one5 Innovations custom gauge pod for s14
green at the moment, but some satin black paint would make it look 100% stock
no gauges, but ment for 2 1/16
$120
AEM EUGO wideband with custom s14 single gauge pod (as seen above)
$300, $220 with out pod NOW $175 with out custom pod!!!
no reasonable offers refused.
Thats all i have pics of at the moment
All items are avaliable for pick up in Aurora
Thanks
Derek
