lewtz
April 17, 2006, 6:20pm
1
Have a T 28 for sale about 40000 km’s on it. Came off an r33 skyline. Comes with all new gaskets [2 hot, 2 cold] $300 firm .
Front calipers from a Z32 TT, they are aluminum and require 30mm rotors. $275
Turbo XS blow off valve, works great $80
Parts Are located in Mississauga
Contact by PM only.
do u have pads and rotors, or just the calipers?
I’m sure it has been answered, but will the 300ZX pads, rotors and lines fit with the GT-R calipers?
Pads and lines are good to go… the rotors won’t work if these are the GT-R 32mm ones as the diameter and thickness are different.
lewtz
April 18, 2006, 1:24pm
5
These front caliper do come with the pads (should be replaced) and all the pins and clips necessary.
These are the 32mm calipers. You can go 30 or 32mm for rotors, the diameter is the same.
Heatw
April 19, 2006, 7:46am
6
no it’s not… that’s bs, the rotors are 296mm instead of 280, i should know i have them lol, and it cost me an asssload of money for good gtr rotors
Uniac
April 19, 2006, 10:04am
7
can you please ammend your post. Saying this is a t28 is very misleading.
For those who do not know, a GTR turbo is smaller than a stock redtop sr20 t25.
It’s about the same size as a ca18det turbo.
system
April 19, 2006, 10:10am
8
I was thinking that was Quite a small Turbo
lewtz
April 19, 2006, 1:45pm
9
lucky:
its not misleading because thats what it is, a GARRETT T 28, all you have to do is search it on google for specs, typical procedure for any purchase.
The turbo came off a bcnr33 skyline.
well tech it still is a T28 (just has a different compressor map or what not)
and yes its about the size of a CA “bit bigger” plus its Ball Bearing so it would spool faster then a CA turbo but could not be compaired to a S14/S15 T28 which has a much large A/R…
lewtz
April 26, 2006, 6:25pm
11
bump, brakes, bov, and turbo are still available.
seth
April 26, 2006, 9:30pm
12
what is the bov good up to? psi i mean…
do you have the flange for it?
I will prolly take it off your hands.
lewtz
April 27, 2006, 8:25am
13
The Blow off valve is good for about 30 psi.
No flange, you have to weld a new pipe on, and screw it on.
man u dont have pics of calipers
lewtz
May 11, 2006, 9:55am
16
bump, pics of the gtr brakes are up, the rears in the pic are sold btw
lewtz
May 25, 2006, 12:45pm
18
bump, new prices on the brakes and turbo
sil8t
May 25, 2006, 9:28pm
19
the gt28 is not ball bearing. the comp wheels are bigger dirrect bolt on for the sr20 the gt28R is ball bearing. the gt28 is better then the t25… the t25 is good up about 250whp whereas the gt28 is an easy 300whp
lewtz
June 1, 2006, 6:33pm
20
bump, bov tentatively sold
