bought it but never used the part.this is what they use for ls/vtec to supply the head with oil. Can also be used for a gauge hookup, oil cooler, etc It’s black, I will post pics in a sec.
Retails for like 95 bucks, I’ll take $45 for it
updated with pics
trade?
Ill trade you for 45 dollars
thread pitch and such? how many ports total?
I believe 2 ports total, I will double check today. as for thread pitch i dunno, whatever the stock honda is !!!
heres the link to the mfg website
VTEC CONVERSION KIT
Precision CNC machined from 6061T6 billet aluminum
Easily allows you to add a VTEC head to a non-VTEC block
Can be used for a turbo oil feed to supply your turbo with clean filtered oil
Works with existing oil cooler set-ups and installs in less than 10 minutes
Sandwich plate has two ( 2 ) ports.
1/8" NPT ( pipe ) port
8 AN O-ring ( Boss ) port that will accept numerous fittings
Can be tailored to any customers needs
-Part # Description (Fittings Included)
GVC101 Vtec Conversion Kit -6AN and 6AN for the head - contains 1 each of:
3/4" Boss to AN-6 fitting, O- Ring - Oil Sandwich Plate, Sandwich Plate Housing, Sandwich Plate Center Shaft,
Fitting - Use for Vtec Head to AN-6 Conversion, 1/8" Pipe Flush Plug, & Retainer clip
Note:VTEC Conversion Kit/Turbo Oil Feed “Sandwich Plate Housing” comes standard with a
1/8 NPT ( pipe ) thread port and a -8 AN O-ring ( Boss ) port for the above parts.
bump
bump
SOLD !!!
