ok, time for winter cleaning. i have a bunch of cylinder heads for chevy’s well as several heads i’m not sure what they are for. so i’m putting in the numbers that i read off of them as well as pics of the ones i’m not sure of.
for chevy cylinder heads here are the casting numbers (i looked the sbc #'s up on mortec) . i didnt take pics of them but i can if someone requests it. the sbc heads are all the cast iron heads. the ones i have pics of are misc. aluminum heads i’m not sure what they fit
-1 pair of ‘14022801’ 80-86 305c.i. heads $40/pr
-1 pair of '14014416 80-86 305 c.i. 58cc $40/pr
-1 ‘462624’ 75-86 350/400 76cc $25
-1 ‘3986624’ i’m not sure what it was off of-mortec didn’t list the number but its a sbc head $25
-1 pair ‘3795896’ 62-64 327, 60 cc $50/pr
if you need the date codes for any of these sbc heads i can look and get back to you.
as for the heads i’m not sure of application:
-1 single 4 cylinder alum. head. has S19 stamped in it several times, the S is in a circle. $25
-1 pair v6 heads aluminum, KSS 21924 004 stamped on the end of both,
10127472 cast on the sides of both. 4 DJ on one, 10 DJ on the other (DJ is in circles) no valves, springs, anything, just the heads $35
-1 pair v6 heads, alum. G7S4FF cast into the sides. complete with original cam, rockers and valves. $40
i’m negotiable…make an offer…if someone was really into heads, i’d probably take $140 for all of the heads i have listed here.
