I have a set of infiniti Q45 Front brakes.
2 Calipers complete with pads (About 60% left), pins, shims, mounting bolts etc.
2 Rotors, they are a little rusty on the surface. But, they are not worn at all, 95% left, since they are still measured 28mm(stock thickness is 28mm) thick.
I am asking 250obo.
They are complete bolt on for 240sx with 5 lugs. For those with 4 lugs, the rotors have to be drilled. The calipers work with the stock 240sx brake lines too. They are two piston sliding calipers and provide almost the same amount of braking power as those 300zx brakes. The rotors are 11inch in diameter. And, I think, they will even clear stock s13 15inch rims (Do not quote me on this. Please do your own research).
PM me, if you are interested in buying them. I will email you pictures.
BTW, the brakes are located in Calgary. I prefer local pick up as they are heavy.
