Stock GSR clutch and flywheel, out of a 2001 ~50k on it. Works fine: $45
(install available)
Engine harness out of a 95 integra ls with injectors. the part that goes to the injectors is clipped, but can be easily repaired. $20
Walbro fuel pumps $60 each
Starter off integra GSR $50
clutch slave cylinder off integra gsr $20, i also have a few clutch master cylinders too, one has only 5000 miles on it, ask if you need it
carbon fiber brace, goes between the seatbelt bolts on an integra, I bet it would fit civics too. It looks nice. $30
jack shaft off of a 2003 rsx type S $25
jack shaft off of a b18 b 5 speed $45
sweet mirrors off of an integra, no broken glass $15
Integra tail lights, $10/pair I have 2 pair both in good shape
Integra gas tank door, perfect, no rust or dents $10
b18 complete bellhousing bolts-$10
P75 ecu with plugs, unknown condition…i took the cover off and there is no physical damage and it doesn’t smell like fish, so it’s probably good, all the terminals look good. $25
integra tie rod ends…fits lots of hondas I think…they are $50 at the parts store, these are in good shape $15 each
ITR head sensors and water outlet: $5
ITR vtec soelinoid: $20 these are very expensive from honda, good to have as a spare incase you do something stupid like I have done!
2001 civic LX ecu in an rsx case: $5
