hey guys my buddy Wayne is parting out his integra build, I will leave a list of parts and prices.
here is his phone number: 518 260-9145 text messages preferred. Text him with questions, I just listed this here for him.
$4000 for the shell with 8 point cage full interior, complete roller
$1800 usdm type r transmission 1kmi since brand new only 83miles since synchrotech synchros intalled. Perfect Shape SOLD
$800 Competition Clutch Twin Disc. 83miles on it SOLD
$1000 Fuel System. Sumped Stock Tank, Aeromotive A1000 Pump/Filter/Regulator,Competition Fuel Rail,stainless lines -10an to pump,-8an from pump to rail, -6an return
$500 FIC 2000cc Injectors. 83 miles
$800 RPM NYC Sheet metal Intake Manifold for B16/BBK 72mm Throttle Body
$600 Garrett t3/gt40 blowzilla turbo .82 stage 5 exhaust .70 comp(basically a journal bearing 35r) around 1500 miles on it SOLD
$900 Synapse Ramhorn/3" downpipe/39mm Precision Wastegate/Dumptube SOLD
$200 Custom 3" Catback Exhaust
$550 Hondata s300 w/boost solenoid for pcm boost control SOLD
$800 81.5mm Golden Eagle sleeved block
$450 Brand New 83mm CP Pistons
$300 2000 Mint Gsr Crank
$900 Fully Built Gsr Head All Supertech/Bronze Guides. Around 1500miles
$250 Crower Stage 1 Cams. Great High Rpm Power with Turbo
$200 Used set of Eagle Rods
$200 Precision 880cc injectors SOLD
$200 Skunk 2 Pro Manifold/Stock TB
$200 Act Lightweight Flywheel
$75 Act 6 Puck Clutch Disc
Ill have more engine parts for sale when i tear down the engine in the car. It broke a valve in cylinder #3. That motor is fully built so ill see what is salvageable and list it up later. Im sure ill have a 2nd Golden Eagle block/bottom end for sale once i make sure it is useable.
