Sold my computer, and got a laptop - no need for the additional monitor anymore.
Device : 19" Wide TFT LCD
Brightness : 300cd/m²
Contrast Ratio : 2000 : 1
Viewing Angle : 160/160
Response Time : 5ms
Resolution : 1440 x 900
Supported Colours : 16.2M
Pixel Pitch : 0.2835(H) x 0.2835(V)mm
Horizontal Frequency : 30-83KHz
Vertical Frequency : 56-75Hz
Input Signal : Analog Signal / Digital Signal(DVI)
Input Ports : RGB Port(15Pin D-Sub)/DVI-D Port
Power Type : LIPS(LCD Integrated Power Supply)
Normal Power Consumption : s than 35W
Suspend/Standby : Less than 1W
Power off mode : Less than 1W
Special Feature : Tilt Only: +5/-25
Safety Certification : UL, cUL, TUV-GS, SEMCO
EMC Certification : FCC-B, CE
Low Radiation Certification : TCO-03
Power Saving Certification : EPA Energy Star
Wall Mount Type : VESA
Dimension : Set: 435 x2 26 x 370mm
Dimension : Box: 494 x 130 x 384mm
Warranty : 3 years
Weight : Set: 3.6Kg
Weight : Box: 4.8Kg
It is is full working condition, I hooked it up to the laptop so you guys could see that it works. Cellphone picture:
