LG Flatron M3201C-BA 32" LCD Monitor
can be used as a TV EASILY - thats what I was using it for.
looks beautiful mounted on the walls.
asking 500 obo.
located in toronto
Ive had it for about 8 months
asking 500 obo.
located in toronto
400 firm
Manufacturer LG
Manufacturer Part # M3201C-BA
LCD Type TFT Active Matrix
Surface Hard Coating, Anti-Glare
Diagonal Size 32"
Aspect Ratio 16:9
Max Resolution 1366 x 768
Sync Type Separate / composite / SOG
Max Sync Rate (V x H) 56-75 Hz x 30-83 kHz
Display Colors 16.7 million
Response Time 8 ms
Interface DVI-D, VGA, Component, Composite, S-Video
Features HDMI / Composite (BNC) / Component (BNC) and S-Video inputs
Image Brightness 500 cd/m2
Image Contrast Ratio 1600:1
Image Max H-View Angle 178°
Image Max V-View Angle 178°
Interfaces 1 x HDMI input
2 x component video input
1 x composite video input
1 x S-Video input
2 x serial
1 x VGA input
1 x VGA output
1 x composite video output
Cabinet Color Black
Miscellaneous Lamp Life 50,000 hrs.
Flat Panel Mount Interface 200 x 200 mm
Audio 20 Watts (10 Watts x 2)
Compliant Standards UL, CSA, CE, TUV-GS, SEMKO, FCC Class “B”, VCCI
Power
Requirements Voltage Required AC 90-264 V (47-63Hz)
Power Consumption Operational 160 Watts
Power Consumption Stand by / Sleep 4 Watts
Operating
Conditions Min Operating Temperature 50°
Max Operating Temperature 95°
Weight Unit 46.4 lbs
LCD Monitor
Power Cord
32" Widescreen LCD Monitor
1366 x 768 Resolution (WXGA)
16:9 Aspect Ratio
178 degree viewing angle (S-IPS) Super IPS Technology allows for distortion-free viewing from almost any angle
500 cd/m2 Brightness
8ms Response Time
1600:1 Contrast Ratio
Tile Mode : 4 x 4 available multiplying the size of display
Temperature and Lamp Fault Sensor
LG Flatron M3201C-BA 32" LCD Monitor is a large Flatron Widescreen which produces plenty enough room to watch your favorite media on. This monitor features a 1366 x 768 resolution and a 1600:1 high contrast ratio. There is a 178/178 degree viewing angle that leaves you plenty of room for viewing options. The (optional) stand can tilt and comes with two (optional) right and left channel speakers at 10 watts a piece. The enhanced productivity and ease of use makes the LG Flatron M3201C-BA ideal for professional solutions. This product also comes complete with a DVI digital interface which gives you the option for the latest in digital viewing technologies.
Display Panel: 32" color active matrix LCD (TFT)
Resolution: 1366 x 768 Maximum
Contrast Ratio: 1600:1
Brightness (Typical): 500 cd/m2
Viewing Angle (H/V): 178/178
Cabinet Color: Black
Dimensions: 31.6 in x 3.9 in x 19.4 in, without stand and speakers
Video Inputs: Analog RGB, Digital DVI, Component Video, Composite Video and S-Video
Environments: PC and Mac compatible
so many posts without edit…
just wanted to mention you can plug 4 computers into this monitor and have them all displaying in the tile mode for convience, security, etc.
lock it up
