PM me or call/text 519-242-3965. All parts are located in Cambridge for pickup only, I don’t have the time/desire to meet up, deliver or ship parts.
All prices are OBO within reason. Deals will be worked out for multiple parts!
Pair of 7 spokes, one tire is bitched, the other holds air but isn’t great. $20
S14 Zenki hood, excellent condition, came off of a Silvia. $120
S14 Zenki hood, has a dent by the passenger side headlight, comes with hood pins $50
S14 black leather front seats, showing some wear. $120/pair
S14 5 lug, comes with LCAs with good ball joints, front ARP extended studs and I’ll throw in the rear brakes. $350
Random S13 seats, usual wear. Most of them don’t have sliders. $10 each
Stock suspension, I have a few sets of each S13, S14 and R32. $50 for 2, $80 for 4.
S13 KA rads, $40 each
S13 brake booster $20
S14 KA MAF $60
S13 KA SOHC MAF $40
KA alternator $40
S13 front calipers, can’t remember if they’re ABS or non-ABS. $50/pair
KA starter motor $40
KA non-hicas PS pump with bracket $50
S13 non-hicas rear subframe, minty mint. Bushings already removed, ready for solid aluminum bushings! $120
One single S14 4 lug wheel for some reason, forgot to check if the tire holds air. $10
Stock S13 rear suspension arms. $20 each or $60 for a set of 6.
S13 engine cross member $20
S13 heater core $50
S13 axles $40/pair
S13 SR20 A/C compressor $20
S13 front TC rods $30/pair
S13 front sway bar $20
Brake master cylinder and booster, not sure if it’s from an S13 or S14 or if it’s ABS or non-ABS. I’ll check this weekend.
rear calipers and popup headlights in these pictures are not for sale
S13 automatic KA transmission. $FREE!! ZOMG FREE!!!
S13 analog gauge clusters, these are DOHC clusters that have had the tachs switched out for SOHC ones. $20 each
S13 analog cluster harness $20
IIRC all the drive shafts are non-ABS
S13 automatic $30
S13 manual $60
S13 rear section $20
R32 GTS rear section $40
S13 SR20DET side mount intercooler, no piping. $50
Black S13 dashboards, $40 each
S14 exhaust, stock with a magnaflow twin tip muffler on it. Sounds decent $80
Sorry for the shitty picture, it’s the one in the middle.
Thanks,
Brendan.
