FS: LS B18 parts and wheels *Pics of wheels added*
All parts are B/O.
2- heads 1 of them would need to be resurfaced and put back together.
The other head appears to be in good shape it does have a valve and spring missing but i have plenty of extra that i can put in there.
-stock cams and cam gears
  • intake manifold. Needs a little cleaning but other then that in good shape.
  • drivers side rear disk set up. Can only be used for parts because the actual arm is bent and it is missing the caliper.
  • integra stock rear sway bar.
    -civic stock radiator fan
I also have a set of 16" 4x100 rota sub-zeros in gunmetal three of them are in good shape with good tires, the fourth has a bent lip on the inside and outside of the wheel and the tire is shot. It does look repairable though.
hmm , interested in the wheels, can you pm me some pics??
im interested in the wheels also…pics?
i will try to get pics up soon
bump. price for the wheels is 250 there is three great tires on them. for the heads $50 a piece
still waiting for pics? maybe? thanks
pics of wheels yo
it is impossible to repair a bend in a cast wheel without compromising its structural integrity, just FYI.
here is the only pictures i have now. The first one is a good wheel and the second one is the one with the bent lip. i really think it will still hold air and the only reason it went bad was because of the crack in the sidewall.
[ATTACH]2891[/ATTACH]
[ATTACH]2892[/ATTACH]
