this was the system i had in the spec. hit 141 dB in the box that is shown
asking 350.
subzone vented box 2 cu. ft/per chamber
xl100 subs
HK2000d amp
xl1200 subs
specs:
- 12" Competition Subwoofer
- 1200 Watts Power Handling
- 600 Watts RMS Power Handling
- Dual 4-Ohm Voice Coil
- 240oz. Double Stacked Strontium Magnets
- 29 lbs a piece
hk 2000d amp
specs:
Power Ratings
RMS Power @ 14.4V
750W @ 4 Ohm
1000W @ 2 Ohm
1500W @ 1 Ohm
Fuse Rating: 40A x 4
Remote Gain Control
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
1 Ohm Mono Stable (HK2000D)
2 Ohm Mono Stable (HK4000D)
