I am selling because I am doing another one with a different theme.
This valve cover not only has the skulls within the flames but also has tiny skulls done in gold flake all through the clearcoat.
I use only House of Kolor paints, and everyone knows my artwork is quality stuff. This valve cover has never been heat cycled on the car but the paints have been proven to stand up to the heat very well, partly because of the powdercoat base I do on all my valve covers that helps shield the paint from the heat.
This valve cover is plumbed for -10an fittings for vents instead of a typical PCV setup. You can go back to the standard PCV but you can use the vents to a catch can or however you’d like to figure it out.
The holes in the plug cover are designed for use with 10.4MM wires that come out through the top of it, you do not have to use them for this purpose but that is why they are there.
Any questions ask!
I know it clears the hood on a 2g, I’m not sure if it does on a 1g, I’d imagine it would.
Asking $250 + shipping for this.
