Fidanza Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is very special. Fidanza uses 1050 high carbon, alloy steel. It is incredibly durable allowing the user to use just about any clutch disc material available from organic to Kevlar and even sintered iron. The friction plate can be machined or replaced as needed. The plates are secured with 16-20 hardened aircraft quality screws with self locking nuts which prevents any warping. Fidanza uses hardened ring gears that are swarted to the flywheel, with button head screws that are counter board between the flywheel and ring gear to prevent any possible slippage. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
* Ultra Light and Weighs only 11 lbs
* SFi 1.1 Approved 2 Part Design with replaceable clutch contact plate delivers the highest quality and longest service life of any flywheel available.
* Fidanza Flywheels work with Stock, ACT, Clutchmasters, Centerforce, EXEDY and Similar OEM-Sized Clutch Kits.
ASKING $350!!! clutch not included
