FS: S13 KA 5spd Transmission, Bee-r Rev Limiter, randoms
got some left over parts from the car, NEED GONE ASAP… make a reasonable offer if you don’t like the prices…
i have
-93 KADE 5spd Transmission, has 180,000kms when i took it out to do the SR swap - $150
-AUTHENTIC Bee-r Rev limiter (that won’t blow your engine) - $250 (check out FRsport, they go for 499 for a REAL one)
-Wiring Specialties S13 SR into S13 harness with Z32 and Factory SR MAF connectors
-Z32 MAF - $75
-Genuine Nardi 330mm Suede steering wheel (no scratches on front side of wheel - suede is a little worn down, no tares)- $150
IF YOUR INTERESTED ENOUGH, I WILL SEND YOU PICTURES IF WANTED
I WILL NOT REPLY TO PMS, DONT BOTHER!
LOCATED IN SCARBOROUGH
TEXT OR CALL ONLY - 647-333-8285
