FS: S13/S14/GTR Parts
Hey guys - since me newly decided move to an S30 chassis, and a recent shop cleanup; I have found an assload of parts I no longer need/cannot use. All stuff is best realistic offer - I will put prices up as need be, and pics as need be.
  • JDM S14 Silvia 5 Lug hubs with ARP extended studs, decent rotors and closed end nuts.
  • R34 GTR clean rear subframe, 5 bolt hubs, 5 bolt axles, ebrake cables, no diff. Bolts up to S14 no issues, bolts up to S13 with offset bushings. Bushings in subframe are good.
  • What looks like an R32/Z32 diff? (6 bolt even spacing, beefy, cooling fins on rear cover)
  • Two S13 open diffs ready for some weldement
  • S14 front subframe with balljoints, engine mounts
  • 2 x S14 front control arm I suppose you could call them.
  • Black S13 Dash pretty good condition
  • Brown S13 Dash decent condition
  • JDM Silvia S14 Dash black pretty good condition
  • R34 Hicas Pump
  • S14 KADE fuel rail with injectors all work great
  • S14 glass all around - all still connected to a bit of metal where it was cut out. If u take the glass in metal I’ll let it go for dirty cheap, if I have to take it out, expect much more lol.
  • S14 KADE Alt
  • S13 KADE short block
  • S14 KADE p/s pump
  • S14 Blower motor
  • S14 Heater Core
  • S14 A/C box
  • S14 Brake booster, master cylinder, resevoir, pedals
  • S14 clutch master, resevoir, slave, pedals
  • S14 Gas pedal
  • S14 KADE 5 Speed tranny shifts good
  • S14 Front Calipers rebuild would be best
  • S14 Gas Tank
  • S14 trunk black with wing
  • S14 outer taillights zenki
  • S13 KA24DE Cluster
  • S13 White chuki bumper with clear corners
  • S13 Pignose lip with a crack, bedliner black
  • S14 seat dyed black
  • S14 passenger side door power everything works, oem tint
  • S14 rear interior panels black
  • S14 Steering Column with wheel and combination switches
  • S14 Passenger side front seat belt black
  • Zenki drivers side headlight no corners
  • Nighthawk bulbs for S14
All parts can be delivered if price is right. Don’t hesitate to ask if you need a part - we may have it.
PM me or TEXT 5 1 9 - 4 0 4 - 3 2 5 3
Thanks Guys.
would you part out the ARP extended studs?
If someone wants the hubs without studs
ill take the hubs
are all these s14 parts off the same car? how many km’s approx on the tranny ?
how much for the chuki bumper ?
Most parts are off same s14 but not all.
Bumper with corners same price i paid - $35?
Make an offer on hubs and studs Ruskii/Boost Hungry. Hubs are clean, as are studs :slight_smile:
pm me your ball park pricing
how much for the s14 heater core?
Where are u located?
**Also have
-4x Denso 550cc top mount injectors
-Fidanza KADE Flywheel in good condition
-Z33 6MT Transmission in very very good condition
All 5 speed parts are gone.
Also have
-2 KA oil pans, one with turbo flange JB welded in, one just OEM.
-DOHC P/S line in minty shape ~ 2 yrs old OEM nissan
Seems the most popular item is the silvia 5 lug, however everyone who has said they wanted them has bailed, including me meeting them in milton and not showing up (not cool.)
Throw out some offers im very flexible as we are moving shops and I need to clear out :).
Also if someone wants the s14 glass - come tomorrow and have it for free, otherwise its going to dump.
how much for the 5 lug swap? its Bolt on for a s13? Pm me your price
Bumpity - have pretty much everything still - Ive had 6 people flake on buying the 5 lug for some reason :S Im in kind of a tight spot so anything I don’t need atm is pretty much available.
  • Garrett GT3076R 0.60 A/R, zero shaft play
  • Fidanza KA flywheel in good condition
  • Brian Crower Stage 2 Cams
  • Denso 550cc injectors (FC TII)
  • R34 Hicas Pump
  • S14 glass all around - FREE
  • S14 KADE Alt
  • S14 Blower motor
  • S14 Heater Core
  • S14 A/C box
  • S14 Gas Tank
S14 5 lug is a pair or a set?
Oops sorry - its front pair
Thats 7 people who wanted to meet for the 5 lug and left me hanging out in Milton waiting. Not cool.
Bumpity - make some offers I’m flexible on most of the stuff.
PM’d you
PM me pics of the Black S13 dash, thanks :slight_smile:
