Well, I am upgrading my front brakes so I have my old ones for sale. These are off of the SR20DET model, which is larger than the CA18DET models. It measures 280mm across and 22mm deep(airgap) compared to the other S13’s 250mm / 18mm. So not nearly as big a upgrade as say Z32 300ZX brakes…but still a significant upgrade. These will fit behind most rims, and are a direct bolt on affair with the same bolts, and brake lines, very easy. You get the rotors, calipers, brand new pads(used for about 2-3 months), and brake lines. Everything you need. There is TONS of meat left on the rotors and obviously on the pads as well. and they have only the ussual minor surface rust. If someone is interested I can also include the master cylinder. The rotors are drilled for both 4bolt and 5bolt nissan patterns, making these perfect if you want to upgrade your hubs.
I will sell them as is (slightly dirty, nothing abnormal) for $150
or if you want I will clean them, paint them gloss black, and machine the rotors for an extra $100 (the machining cost $50, but isn’t NEEDED it will just make them look alot better and eliminate the chances of them being slightly warped, which they shouldn’t be)
I live in Grande Prairie, but can bring them to Edmonton if someone is seriously interested.
All I have for pics right now is the rotors, but if someone REALLY wanted another pic of the whole assembly, I could get one.
