Welcome to the I need to sell parts to buy other parts sale.
I ended up buying 2 part motors last summer to rebuild mine. Most of these parts are the extras left over.
PM or txt me at 705 seven 4 one 9 five 0 one
willing to meet closer to the city on some stuff as I live in peterborough. Willing to ship small parts at buyers expense.
If my prices are off just say so or send me an offer everything is obo.
Things I need and would trade for are Haltech for s14, 1000cc top mount injectors with rail or spitfire coil packs.
everything for s14
-Kyle
S14 ECU With Nistune Board Installed, consult cable and software included (transfered into your name/email)
bought from veloz
What is Nistune?
Well, Essentially, it’s a hacked ECU.
You can change all the tables like a full standalone yet still maintain the usability, and drive-ability of the stock ecu.
fully Open, Fully Tunable. Real time tuning, Logging etc.
Make changes to Timing, Fuel, Knock, boost by RPM, Injectors, MAF, Rev limiter, Speed limiter, WB AFR’s
$650
S14 WC ecu with RS-ENTHALPY board in it.
came with stock s14 sr so i assume that is the tune on it. I did not personally see it run but you can send it in and get it retuned for your setup.
$350
Second stock WC ecu that is from my car and was working when removed
$100
Sparco Viper Fang 2 wheels with Nexen 3000 tires
rims are 16x7 with 225/45ZR16 front and 16x8 with 245/45ZR16 in the back.
4/5 114 bolt pattern
fronts have bit of camber wear but can be flipped.
comes with 2 5mm and 2 10mm matching spacers (4 and 5 bolt aswell)
all center caps and plastic socket for removing them included.
back rims have break dust and could use a good cleaning.
$1000
Apexi Hybrid Front mount intercooler with new hotpipe and all piping to go from turbo to throttle body. Uses factory side mount holes for install. No cutting required.
$600 obo
Set of 550 Deatschwerks Injectors with fuel rail
used for last year
$300
2 sets of s14 stock cams both in good condition
$100 each set
1 set of not so good s14 stock cams (dont pass finger nail test) if someone wants to polish them and use them
$25
Isis Z32 MAF with pig tail
flange cut off to use silicone coupler on both side
$100
S14 sr maf with apexi intake kit
$100
http://www.frsport.com/APEXi-507-N005-Dual-Funnel-Power-Intake-Kit-S14-S15-SR20DET_p_899.html
3 Lower oil pans for sr (will be cleaned out prior to selling) first one sold gets the one with magnetic oil plug
$30 each
S14 sr throttle body with TPS
$50
grill that came with my silvia. no broken tabs
http://www.ebay.com/itm/JDM-NISSAN-240SX-SILVIA-S14-FRONT-GRILL-GRILLE-ZENKI-1995-1996-/131093770818
$100
factory fuel rail with injectors from sr
$150.00
2 s14 valve covers
$100 each
set of coil packs with harness
$100
set of oem pistons from what I was told was a recently rebuilt sr
$200
another set of oem pistons from the other 2 srs (6 total 3 from each motor) pick the 4 you like and use them.
$100
IAC solenoid
$75
CAS
$50
Coolant fitting (BNIB) Part 14075-65F00
$20
water neck
$40
lower half of plenum
$40
USDM clear turn signals one has a crack
$20 both
Navan front bumper cut to fit over big intercooler
$50 sold
Navan Rear bumper
was on my car when I got it. needs paint.
$100
Ractive reclining race seat
bit dusty but no rips,tears,burns etc.
$100
JDM twin tip muffler
came with car wrapped in newspaper and JDM bondage tape what else could you want
$30
sub box with 9" holes (I assume 8 inch subs) no subs
$20
Motegi MR116 Rims with good tires
Price 650 obo
Offset: ET40
4 bolt universal
2 tires are Wanli 215/40ZR17
2 tires are Nankang 215/40R17
also includes 1 extra rim with rash and 1 extra tire
RTX Kinetic Rims with dead tires
Offset: ET42
4 bolt universal
Painted 2 years ago and is peeling. straight with no dent minimal rash. was going to sandblast and use as track rims. tires are no good and cant be driven on.
$100
I also have 2 heads full of parts
valves +/- a few bent ones, springs, retainers, shims, rocker arms, etc
also 3 blocks worth of misc parts. just ask if you need something specific.
