SEEMS LIKE THIS FORUM HAS A PROBLEM - IF YOU DO NOT HAVE MONEY, ARE NOT SURE WHETHER YOU WANT IT, ARE NOT SURE WHETHER IT WILL FIT YOUR CAR, ARE WAITING ON A PRICE ON THE SAME ITEM FROM SOMEONE ELSE, ARE NOT WILLING TO DRIVE TO AURORA TO PICK IT UP, YOUR CAR IS BROKEN AND YOU CANNOT COME TO PICK IT UP, OR ARE GOING TO REALIZE THAT YOU NO LONGER HAVE THE MONEY AS IT MAGICALLY DISAPPEARED ON THE WAY TO PICK THE ITEM UP - THEN DONT FUCKING PM ME!!!
APR CF wing - 350$ (hatch is sold already)
silvia grill 50$
magnaflow s-chassis flanged 3inch stainless high flow flanged cat 150$
95 s14 ka 5spd ecu 50$
95 s14 ka maf 50$
momo wheel with hub 100$
s14 passenger airbag 100$
180sx brake master 50$
non hicas ps reservoir 40$
4lug front hubs 50$
4 channel L.A. Sound amp 100w x4 150$
sony 2channel amp not very powerful but neat 90$
s13 non abs vlsd - 80$
s13/s14 axles - 100$
sr tranny dust shield - 20$
rubber inner shiftboot/bracket - 20$
s13 sr coolant neck - 30$
srcoilpack harness - 40$
sr cam caps - 5$ each
sr stock oil block - 20$
sr cam oil squirters - 30$
theres other stuff in it i dont remember
take the whole box for 100$
sr fan shroud - 30$
s14 stock drivers seat, great condition - 100$
pair of brand new federal ss595 245/40ZR18 - 250$
apexi hybrid s14 fmic kit - 300$
stainless catch can with fittings, disassembled but u can easily put it back together - 40$
stock straight coupler - 30$ each
random red braided couplers - 30$ each
take all couplers - 60$
namco horn button from a Midnight Wangan MaxTune arcade machine - 50$
MAF adapter - 20$
1 aftermarket steering rack bushing - 30$
small aluminum catch can with two fittings and clear glass level twist off style and drain button - 40$
s13 ka-e cluster - 20$
s14 usdm zenki cluster - 40$
autometer used boost gauge - 60$
omori boost gauge - 100$
koyo 1 inch thick copper rad with aluminum fins, jdm stock replacement - 200$
stock sr rad hoses - 40$
s13 hood hinges - 30$
jdm glow in the dark funny pedals brand new - 50$
sr coilpack covers - 30$ each
stock sr flywheel - 30$
stock sr pressure plate - 20$
s13 headlight covers with built in sparco kill switch clears headlight housing and can retain operational popup lights - 80$
sr power steering pump - 150$
din pockets with bracket - 30$
s13 rear banjo ss brake lines splparts used for 300km (not 3000) - 50$
aftermarket replacement sr20det clutch w/ press plate/, tob has literally less then 100km on it, 300$ minty fresh
adjustable wastegate actuator - 50$
8 extended front studs s14 front hubs - 50$
pioneer front aftermarket speakers 6x9 3way - 50$
pioneer rear aftermarket speakers 4x6 3way - 50$
or 80$ for all 4 (fit s13 hatch)
teardrop centercaps - 20$
s13 silvia washer tank - 50$ (allows bypass of aftermarket fmic coldpipe and retain washer tank)
stainless steel coolant expansion tank with gauge and four 1/4 inch stainless nipples - 100$
s13 passenger seat base (one of the legs doesnt reach but can space it out with a pair of lug nuts) - 80$
s13 popout light trim - 20$ take all
s14 sr upper intake manifold with iacv - 50$
-stainless stuff from left to right-
nissan throttle body sized flange with stainless extension - 80$
3 inch regular stainless exhaust flange - 40$
greddy box stainless flange with stainless extension - 50$
3 inch stainless pipe with vband flange tig welded in and vband clamp - 80$
stainless 3 inch vband (one side, sitting on top) - 20$
pair of 4lug 10mm bolt on spacers (studs have honda threads i think though, standing up vertically along the stack of 25’s on the left) - 50$
pair of 10mm 5x114.3 hubcentric ichiba spacers pretty much brand new (standing up right) - 80$
stainless gt28/gt25 garrett to 3 inch vband adapter, with vibrant vband and clamp, to stainless elbow down) - 250$
r33 rear knuckles (will work with s13/s14 if you press out the balljoints and press in bushings for the toe arms) - 50$
s14/r33 rucas - 30$ a set
s13/s14/r33 traction arms - 30$
s14 stock tc rods with only 300km on them bought form dealer - 80$
s14 tc rods with energy bushings - 120$
mint front swaybar endlinks - 50$ a pair
s13 inner steering tie rods - 20$ each
s13 outer steering tie rod ends - 20$ each
s13 balljoints - 30$ both
s14 balljoints - 30$ both
s14 passenger side flca - 30$
random bits of stainless and waht not - 50$ for the box
electric fan - 30$
s14 fender liners - 50$
s14 stock suspension great shape - 120$
sr ac compressor with bracket and bolts and belt - 80$
s13 front tanabe sway bar - 220$
s14 rear largus sway bar - 275$
both - 450$
apexi afc neo - 250$
apexi rsm - 80$
greddy speed cut defend - 75$
s13 digital turbo timer - 75$
xline oil press gauge no sender 50$
s13 crossmember - 50$
ca18 downpipe - 30$
engine stands - 40$ each
tires still good for drift (2x 225/45/18 contis, 2x 245/40/18 federal ss595)
50$ all four
s14 stock catback - 100$
PM IS THE KEY
