i just swapped my '90 automatic to dohc 5 speed and i have lots of parts kicking around form the swap that i’ll let go for cheap. all prices are obo. and i will part out the engine unless i hear from someone this week (before the weekend) that they want the whole thing.
complete sohc engine - 220,000km pulled quite well for a single cam auto. problems with the motor are that some of the exhaust manifold studs are stripped from the head and the EGR tube to the intake mani was cut and pinched off by the previous owner. engine burned a bit of oil too, not sure why. $120
auto trans - 220,000km works awesome, shifts very nicely. $50
sohc auto ecu - worked great, a little rust on the case $20
sohc ignition coil - worked well $15
clutch fan and fan shroud - good shape, give me the change from your pocket and you can have them.
edit: wow i posted in the wrong section, i am dumb. can someone please move it for me, thanks.
