$$ 800.00 $$ OR B/O
Detailed Description of the TRA800.2:
TRA800.2
Soundstream TRA800.2 2 Channel Amplifier
Variable hi pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
NUMBER OF CHANNELS: 2
OUTPUT (WATTS):RMS @ 4 Ohms 200x2
RMS @ 2 Ohms 400x2
RMS Bridged @ 4 Ohms 800 X 1
T.H.D.: Frequency Response (Hz): 10 - 50k
SIGNAL TO NOISE RATIO: >115dB
DAMPING FACTOR: >500
INPUT SENSITIVITY: 0.15 - 12.0V
CROSOVER SLOPE: 12dB
CROSSOVER FREQUENCY (HZ): 50 - 5k
DIMENSIONS (INCHES): 10.75x2.6x21.5
Soundstream 1-Year Warranty
THE SUBS ARE MMATS 12 INCH dual 4 OHM , 400 watts
