– UPDATE –
whatever is left on the list is everything I was able to find space to stash before I moved and it is still available.
I WILL BE IN THE BUFFALO AREA FROM WED 7/28 TO SAT 7/31 and will be able to meet up and/or ship stuff out. If you might be interested in anything you see, shoot me an offer asap cause it might be your last chance to grab it up as none of this is coming back to nc with us
All prices listed are best offer unless otherwise specified. Willing to ship anything pretty much wherever.
also possibly willing to trade anything here for any of the following:
- B-series supercharger stuff - alternator stepper pulley, LHT setup, laminova cores, etc
- Hondata S300
- E36 or E46 BMW
- GM 6.5L turbo diesel engine/swap/complete truck
- CTDi Accord (TSX), left hand drive, able to be legally titled & registered in the US
HONDA/ACURA STUFF:
GSR trans - Hydro manual 5-spd, most internals are in ec but synchro sets should probably all be replaced as long as its out and a few gears could use replacing if you want it to be 100% perfect $250/bo as is I can also do the work for you while I’m in town, pm me for quotes
Eagle H-Beam forged rods - B18C1 Brand new in box, only selling because I came across a siqq deal on another set of rods with the pistons I wanted already installed $250/bo
GSR stock rods & pistons - Came out of my perfect running B18C1, they were only removed because the motor is being rebuilt with all forged internals $50/bo
JDM B20 Exh manifold/downpipe - Both excellent condition. Deletes cat (ie- oem race/test pipe) $50 both
B-Series Flywheel #2 - stock weight, needs resurfacing $15/bo
B-Series Flywheel #3 - stock weight, has a clutch bolt broken off in it $15/bo
B-Series clutch #1 - Exedy stage 1 organic, has probably less than 2k on it $150/bo
D-Series Flywheel - stock weight, good to go $20/bo
D-Series clutch - pretty sure its oem or oem replacement, came w a trans I picked up for a project. Still tons of life left $30/bo
B-Series power steering pump - P72, fits gsr & non-vtec models. Have mounts, pulley, reservoir, and pump to reservoir hose $40/bo
GSR stock intake manifold - OBD2 out of a 96 teg, only removed to make room for supercharger setup. $35 pics up asap
GSR stock differentials (2) - Have 2 in GC, both came out of clean trans, only removed for upgrades to lsd. Both have good stock tapered bearings and speedo gear $35 each as is or I can weld if you want
D16Y8 stock differential - GC, came out of a clean trans. Has good stock tapered bearings and speedo gear $25 as is or I can weld if you want
B-series alternators - Have 2 OBD2, none have good pulleys $25 each
1999 CRV RT4wd 5spd manual trans (B-series) - UBER RARE & very hard to find. Was planning on using this for my AWD build but have decided to go a different route. Also have all info you need to convert this to close ratio gearing w/LSD $450/bo
B-series oil pump - obd1 off a low mileage JDM B20, only removed cause had to change to obd2 style pump w ckf sensor to pass nysi $25/bo
2000 Si 15/16" Brake master cylinder - Bought new from NAPA hoping it would improve my stock brakes, it didn’t make any difference. Has less than 4 miles on it $50/bo
2000 Si 15/16" Brake master cylinder + 270V Booster combo - These were stock on my 2000 Si, removed when I swapped to ITR 1" mc + booster. All in VGC, never had any probs $75/bo
F22 trans - 5-spd manual out of a 95 Accord EX coupe. Ready to drop in, no grinds or any other probs. It was only removed to make room for H22 swap $150/bo
USDM D16Y8 (96+ sohc vtec) cylinder head swap - complete head w/cam, all valvetrain, vtec solenoid assm, and USDM D16Y8 intake manifold. All in very good shape $150/bo pics up soon
Stock black F22 valve cover - Never installed since refinish $20
Red F22 valve cover - Never installed since refinish $35
Black D16Z6 valve cover - Refinished in satin black $35
P2E ecu (#1) - manual trans, came off running engine $20/bo
P2E ecu (#2) - auto trans, not sure if good or not. Buy for parts, tuning, experimenting, etc. No bitching if DOA!! $10/bo
P2E ecu (#3) - manual trans, has faulty bypass valve circuit. Buy for parts, tuning, experimenting, etc. $FREE come get it
P05 ecu - manual trans, came out of a good running car that was swapped to B-series. $PENDING
D16Y8 Lower timing cover - BRAND NEW still in Honda packaging $10
94-97 teg driver side headlight - gc other than low beam reflector is cracked. Comes with bulbs $10
Honda oem cassette deck - Good working condition, with cd changer control. Fatty red display. For the oem snky effect- stupid tape deck in the dash but cd changer in the back $30/bo
POSSIBLY F/S:
2000 CIVIC Si COUPE - SUPERCHARGED, Black on black, clean body. Car is fully loaded as Si models are - power everything including retractable sunroof, working cruise & a/c, tilt wheel, etc. Jackson Racing street (~7psi) supercharger kit installed on the stock B16A2 engine along with CTR cams, Fidanza 7.5lb flywheel, Exedy stage2 clutch, B18C5 LSD trans w GSR 5th, B18C5 axles. Suspension consists of H&R sport springs on Koni yellow adjustable shocks, 26mm front/22mm rear sways, ASR rear subframe brace, Skunk2 camber adjusters front + rear, professionally aligned. Exterior is stock aside from real Spoon Sports carbon fiber side mirrors, oem CTR headlights w/ city lights, and oem clear fog/driving lights in the front lip. The car sits on gunmetal 17" Axis Se7ens, bronze 17" Konigs, or white 15" Kosei K1s depending on the day lol. Alpine detach face cd deck w/remote, polk speakers all around including front separates. Also has full feature Compustar security system with pager, remote starter, supercharger cooldown feature, several hidden starter/ign/fuel kills, etc etc. Its the car in the pic above with the 17" boss alloys. No corners were cut anywhere on this car, everything has been done right. Its a gorgeous car that’s a blast to drive. More pics available on request or just come see it in person, you won’t be disappointed.
$10k/bo gets everything listed… pretty firm on this for now, serious parties contact me via pm or email
GM STUFF:
GM NP136 electronic shift AWD transfer case '98+ - This was removed and replaced under warranty at the dealer and GM said it wasnt worth it for them to take it back and try to repair it, so I ended up with it. If I remember correctly, it was weeping fluid from a small spot on the case that was determined to be a porous casting flaw when GM was having alot of issues with that around that time. So if you can tig/jb weld/epoxy/etc the bad spot it’s a perfectly good working unit otherwise as far as I know $50/bo
1993 Jimmy seats - Charcoal w/ red stripes, damn near mint cond. These were intended for a friend’s project years ago that never panned out $50/bo
1993 Typhoon leather seats - Black leather, 8-way power. Damn near minty. Also have matching door panel leather pieces for syclone/typhoon/1st gen s10/blazer/jimmy/bravada/etc. REALLY hate to get rid of these but I don’t plan on putting them into anything anytime soon $450/bo
1993 S-10 Blazer chrome grille - fits 91+ 1st gen s-trucks, 82-90 with minor mods $20/bo
sbc flexplate - fits sbc, 3.8L/4.3L v6 $20/bo
4.3L tbi intake manifold - stock, from a 92 jimmy $20/bo
4.3L tbi distributor - from 1992 jimmy, should fit any tbi 3.8L/4.3L $30/bo
Alternator - virtually new, fits early 90s vin “W” vortec 4.3L and definitely others. Bought this for my 5.7L swap but it wouldn’t work with the accessory brackets I was using $30/bo
S-truck overhead climate/compass display - pretty sure this fits both 1st and 2nd gen overhead consoles $25/bo pics up soon
1227730 ecm - Speed density style tuned port + others, ecm connectors w/ 8" harness pigtail included. [http://www.exatorq.com/ludis_obd1/p4xref.html#1227730"]click]([URL) here for applications $30/bo pics up soon
1227747 ecm - [http://www.exatorq.com/ludis_obd1/c3xref.html#1227747"]click]([URL) here for applications $20/bo pics up soon
16144288 ecm - [http://www.exatorq.com/ludis_obd1/c3xref.html#16144288"]click]([URL) here for applications $20/bo pics up soon
1st gen s10 gauge cluster #1 - rare tach cluster with full gauge package, mechanical speedo $20/bo pics up soon
1st gen s10 gauge cluster #2 - Canadian (metric), has full gauge package $20/bo pics up soon
MISC STUFF:
Dual filter relocator - Came on my gf’s ek hatch, we didn’t really need it. Takes 2 of the larger PF-2(?) filters, but pretty sure you can use smaller ones as well (PF52/47?). With or without spin on adapter plate for Honda blocks. Worked great before it was removed, no leaks or anything $35/bo
DSM side mount - Was planning on using this on my eg civic but plans changed & then I sold the car. I never pressure tested it or anything but got it from a reputable member on here $20
Helmet #1 - Bell open face, face shield included. Its older, out of spec and the padding is pretty worn out. Good for practice, starter/kids, decoration? $10/bo
Helmet #2 - Vetter lightweight fiber 3/4 shell, face shield included. It’s older & out of spec, but padding is still good. Good for practice, starter/kids, decoration? $10/bo
