FS: Various car audio
First: Head units
Alpine CD Head unit - can’t think of the model number off hand- ROFL 10$
Plays cd’s, radio works good, has subwoofer RCA outs. Great backup radio. Great for a backup car especially because who wants to worry about nice shit in their backup!
http://i223.photobucket.com/albums/dd300/eliteemerz/ForSale/3176792d-8d5b-44c3-aac3-10076a914559.jpg
Alpine CDA-9857 65 obo
CD player with built-in amplifier (18 watts RMS/50 peak x 4 channels)
flip-down, detachable face with 2-line BioLite display
plays audio CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA music files)
Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
BBE processing
Source Tone Memory
three sets of preamp outputs
HD Radio-ready
controls for an optional XM or SIRIUS satellite radio tuner
compatible with an iPod using Alpine’s Full Speed controls
CD changer controls
remote control
clock
CEA-2006 compliant amplifier
CD frequency response: 5-20,000 Hz
CD signal-to-noise ratio: 105 dB
FM sensitivity: 9.3 dBf
Has a pretty short harness but I’ve extended all the wires to a reasonable length. Works great. I’ve seen this used in 2 different cars. Was given to me as payment for an subwoofer integration. Has iPod adapter. I can include my old 8GB iPhone 3g (jailbroken and unlocked, good for a backup phone even. Broken vibrator, silent switch, and headphone port.) for an extra 20$. I always have used it in my car because it only functions about 50% overall but works great as a cheap MP3 player you can leave in your car and not care about. I also should have the sleeve/trim in my tool box.
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_20130604_125252.jpg
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_20130623_152018.jpg
Alpine IXA-W407 Media Center with 32gb iPod touch 4th gen 300$obo
Works great. Dual din. Comes with iPod to use as your cars hard drive. It’s missing the screen but since you control the iPod from the deck it doesn’t matter. Still plugs in and syncs right to your iTunes. I don’t want to sell it but I will if I have to.
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_20130323_163206.jpg
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_0126.jpg
Subwoofers:
2 10" Nakamichi Subwoofers in Ported box 85obo
300peak (each)
150rms(each)
Sound good. Hooked up in my trunk now
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_20130604_125225.jpg
Amplifiers
Rockford Fosgate Punch 700S 135obo Pending sale
Details:
175 watts RMS x 2 at 4 ohms
350 watts RMS x 2 at 2 ohms
700 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
50-210 Hz high-pass/low-pass crossovers, 12 dB/octave
wired remote control included for fingertip control of Punch Bass (boosts bass 0-18 dB, centered at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for “intelligent” shutdown protection
speaker- and preamp-level inputs
8-gauge power and ground connectors
Nice amp. Good condition.
http://i223.photobucket.com/albums/dd300/eliteemerz/IMG_20130604_125413.jpg
Alpine MRP-M1000 Amplifier - 120obo
Currently not working. It will cost me a few more bucks than I’m willing to spend to repair it without a buyer lined up.
mono subwoofer car amplifier. Doesn’t have end caps.
600 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
variable low-pass filter (50-200 Hz, 24 dB/octave)
variable bass boost (0-12 dB at 50 Hz)
subsonic filter (15 Hz, 24 dB/octave)
Class D amp with MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
gold-plated screw terminals
fuse rating: 25A x 4
4-gauge power and ground leads recommended
Speakers:
2 5.25" OEM Volvo pillar speakers (10$)
Work great. Took them out of a friends car I did a full component system in. Good for cheap replacements. Very shallow mounting depth, but still crystal clear sound.
http://i223.photobucket.com/albums/dd300/eliteemerz/CAM00214.jpg
5.25" Component Speaker Set (40$)
2 5.25" Phillips Midbass Drivers (they were powered speakers from a friends volvo, wouldn’t have replaced them if he didnt make me! pretty nice set!)
2 Alphasonik Tweeters
2 Alphasonik Crossovers
I’ll get more pics when I get a second.
http://i223.photobucket.com/albums/dd300/eliteemerz/CAM00213.jpg
Installation hardware:
B6 A4/S4 dash kit
Got screwed and ordered one from crutchfield for 25$ because I needed it fast. I’d like to get 20 out of it, especially since they’re 30-40ish from Boomer and 20+ on ebay.
2006ish-2012ish VW Harness/Dash kit (30$)
Dash kit has 1 broken tab as you can see in the pics, but if you put in 3 out of 4 bolts along with your dash trim it should hold perfectly fine.
Here’s what the dash kit is listed as fitting:
2009 - 2012 CC
2006 - 2012 EOS
2006 - 2012 Golf / GTI
2006 - 2012 Jetta / GLI (MK V)
2006 - 2012 Passat
2007 - 2009 Rabbit
2009 - 2012 Tiguan
Harness is listed as fitting:
2006-2008 EOS
2002-2008 Golf
2002-2008 GTI
2002-2008 Jetta
2002-2008 Passat
​2006-2008 Rabbit
Refer to below
Refer to below
Refer to below
See original post!
Sony pending sale. Once tapatalk let’s me PM him back at least! :laugh:
Sent from my A500 using Tapatalk 2
Combined.
Thanks!
I’ll give you $50 for the Audio Art, I don’t need the x-over.
PMed sir
Sent from my LG-VM696 using Tapatalk 2
Everything pending sale has been left in the post I had everything in. I moved all items that have no potential buyers yet to the first post in the listing. Once items are sold they will be removed.
Would you like to sell it. Just Pm me your response
PMed
Audio art sold thank you sir
Kenwood and Lightning Audio amp sold.
Buyer for sony is holding off for now, still available for anyone interested. Also should have a 12" Alpine Type E later this week. Will take pictures and post specs when I’ve got a chance
I need to scrape some money together. Selling my car to a friend and buying something else, but I need a few extra bucks for tax and registration fees.
Look above for price drops!
MEX-BT5000 dropped from 135 to 125!
Also willing to sell my in dash navigation. The faceplate is missing a tiny cover but the deck works perfect:
Clarion NZ500 with GPS antenna and wiring harness - 150 obo! (missing the mounting sleeve and trim ring, didn’t need them for my car, but you can ebay them for about 20$)
will put up a pic tomorrow
