This 19" monitor is in great shape. No dead pixels, screen is bright and detail is awesome on images. Great for gaming or just the every day user. Never a problem with it ever. Nice anti glare. When this monitor came out it was top of the line, and still holds good value. There’s a BIN on ebay for one for $130.
There is one small problem with it that I know of. The power button (first button on the right in the pic) seems loose. It hangs lower than all the other buttons by about a centimeter or two, I’m not sure if this is a defect or from wear. It still works and turns on fine though. Doesn’t effect the performance of the actual monitor. If you want a picture of what it looks like, I can take one. It’s been like this for probably half a year and the monitor has never not turned on for me.
Asking $100. pretty firm… also putting it up on craigslist so it may be gone fast…
If your looking for a 19" you can probably find a no name brand for about $140 brand new or so after taxes however, it will not even come close to comparing with this monitor in detail and quality.
Full Specs from newegg:Screen Size 19"
Widescreen No
Maximum Resolution 1280 x 1024
Recommended Resolution 1280 x 1024
Viewing Angle 170°(H) / 170°(V)
Brightness 270 cd/m2
Contrast Ratio 650:1
Response Time 2ms
Horizontal Refresh Rate 30kHz - 82kHz
Vertical Refresh Rate 50Hz - 75Hz
Panel Active Matrix, TFT LCD Display Type SXGA
Input Video Compatibility Analog RGB, Digital
Connectors D-Sub, DVI-D
D-Sub 1
DVI 1
HDMI No
Meets TCO’99 and ENERGY STAR standards
Power Supply 100 - 240 VAC, 50/60Hz
Power Consumption 35W (typ)
