Cal
1
Neither the calipers or rotors have been used.
Still in box.
Rotors need to be redrilled if you still want to run 4 bolt.
(JUST the calipers - no clips or pins)
$220 Calipers
$80 Rotors
$280 Buy everything and save!
FIRM pricing
Located in Scarborough/Pickering.
cgguy
2
Does that mean the calipers are Brand new? Re-built? or just never mounted on your car?
Cal
3
Calipers are re-built.
Rotors are brand new.
Both from CT
HOW much is the real question on everyone’s mind.
DIDDO>>Are the rotors blank or are they crosss drilled or slotted > PICS would reallly help…
Cal
6
Rotors are blank.
Pictures?
Picture this…a circular disk.
Hardware can be had for about 50 from Nissan, good pads will cost 100, but you can get away with something for about 50, lines another 100.
so for 400 you can have a z32 swap.
I’d buy this if i had a 240… definitely a good deal.
Cal will tell you if you have dibs or not.
Cal
10
Cal will tell you if you have dibs or not.[/quote]
Word
First come first served.
Might be gone tonight.
