1999 Honda Civic Si-R in black
- 320000km on the body - 110000km on motor - motor (Hwy km from Kingston to Ottawa and from Toronto to London)
- CLEAR title
- black interior with black charcoal leather
- loaded with power windows, heated mirrors, locks, sunroof, steering, heated mirrors, A/C, power sunroof
- B18C5 motor (1.8L DOHC 195hp stock) and tranny with LSD (limited slip differential) - Integra Type R (ITR) motor and tranny
- Skunk2 Stage 1 Cams
- dual seal billet cam seals
- AEM V2 intake
- AEBS Intake manifold
- Upgraded engine mounts (harder rubber, no vibrations like polyurethane)
- Vibrant 4-2-1 header
- JDM ITR cat
- ITR midpipe
- ITR muffler - needs new tip
- OEM fog lamps
- Do-luck floorbar
- rear tie bar
- front and rear strut bars
- Si-R stock wheels
- Compustar alarm
- Eibach Pro-Kit springs - lowered only 1.2"
- ITR Flywheel\Clutch\bearing - NEW installed in September
- JDM ITR shift linkage (gold thick one) and shifter
- weighted (1lb) shift knob and stock one if you really want it
- poly shifter bushings
- OEM CD player with code
- NEW wheel bearings all around installed last spring
- NEW O2 sensors installed this year
- car has no accidents
- just passed emissions test
- oil change every 3000km
- valve adjustments done as per maintenance schedule
- timing belt and water pump done at 250000km
- as is
Needs for certification:
- new rear brakes disc/pads
- windshield
My daily driver, but I need a bigger car. 4dr’s are my main want, but open to anything like a larger 2 dr car. Only reason I want something bigger is because I just had a baby. I already have an SUV so not desperate to sell. I just want another bigger/4dr car.
Contact via PM Leave location and a contact number and offers rades. I will not respond to low balls. If I can’t trade it I will keep it as my commuter car. I am advertising it at $7000obo, but I am looking for TRADES.
