i was wondering if a fwd sr20det exhast manifold with fix and a rwd sr20det block …or the other way around
Do you mean
“I was wondering if a fwd SR20DET exhaust manifold will fit on a rwd SR20DET block, or the other way around?”
likely yes, the manifold bolt locations “SHOULD” be the same, has ANY of us tried it? NO!
If you consider that the KA24 turbo manifold is (not all, but the one I saw) is adapted from an altima(?) FWD.
general answer,
