Cometic Head Gaskets
now at www.GARAGE16.ca
All cometic head gaskets are 4 layer MLS (multi layer steel). Cometic uses stainless steel for increased strength, it’s ability to rebound and corrosion resistance. The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material designed to meet the demans of a variety of harsh sealing enviroments, load conditions, and surface finishes. This coating is also heat resistant to 482 degrees F. The shim layers of the head gasket is also stainless steel but is left uncoated and can be varied for a varied thickness. Cometic MLS gaskets are ideal for aluminum or iron surfaces will seal better than any other gasket PERIOD
*** FOR BIGGER BORE OR MLS, Please call us
Shop Online For Pricing & Apps Here: http://www.garage16.ca/SearchResults.asp?Cat=2360
