Post up your suggestions. The high beam/turn signal option is what I’m leaning towards. Anyone know where to pick this up relatively cheap?
Annnnybody?
just make it. Use a relay inline with the high beam wire maybe? I’m sure its been done.
I just keep my remote in my tank bag
Find a homelink transmitter from any number of cars in a junk yard and wire it up:
diy forum write up http://my.is/forums/f90/diy-high-beam-activated-garage-door-opener-331264/
That was one of a few I was considering Travis.
why not spend 20 bucks and buy a key fob style one?
I just take my extra one and stick it in my jacket pocket, it isn’t really all that inconvenient, and it works on any of my bikes.
I’ll probably end up with the key fob version.
velcro a regular one to the inside of the windsheild?
I took the opener and soldered a switch to it which is mounted in my fairing. The opener is hidden.
The high beam idea is neat but if you leave your high beams on, the switch is being engaged the entire time which will drain the battery. I guess it depends on how much you use your highbeam but I would rather just wire a regular switch somewhere.
The high beam version requires the rider to cycle the high beams twice to activate.
ooh neato. :tup:
next to your car tire?
---------- Post added at 12:24 PM ---------- Previous post was at 12:24 PM ----------
^Boom, Roasted.
