Ok guys I have been dragging my feet on this one but here it is. I will be doing all of my bushings this winter. These Bushings are a HUGE improvement over old and gushy stock rubbers.
Included in the Canadian Dollar prices is All Taxes and Shipping to my place. We can arrange pick up or metting place.
Order will take between 2 to 4 weeks (just incase they have to pull out the 240sx dies to make this stuff).
Your choice of Red or Black
Requirements: I need to have only 5 items ordered for this to go through (kits count as one item).
PRICE REDUCTIONS
If you order 3 or more individual items, I can give you some discounts.
S13
Front End Control Arm Bushing Set…$35.00
Rear End Control Arm Bushing Set…$85.00
Front Sway Bar Bushing Set 24mm…$30.00
Front Sway Bar Bushing Set 25mm…$30.00
Rear Sway Bar Bushing Set 15mm…$35.00
Rear Sway Bar Bushing Set 22mm…$25.00 (for HICAS bar)
Rack and Pinion Bushing Set…$20.00
Front Strut Rod Bushing Set…$70.00
Rear Sub Frame Insert Set…$45.00
Hyper Flex Complete Master Bushing Set…$210.00
Hyper Flex Kit includes the following:
Front control arm bushing set:
2 Sleeve
2 Bushing with built on thrust washer
2 Bushing without built on thrust washer
1 grease.
1 Instruction sheet
Front strut rod bushing set:
2 - inner bushing.
4 - outer bushing.
2 - sleeve
4 - grease.
1 - installation instructions.
Front sway bar bushing set:
2 24mm bar bushing
2 Upper endlink bushing
2 Lower endlink bushing
1 grease
2 25mm bar bushing
1 grease
*(Depending or your bar size, you will not use 2 sway bar bushings but both are included.)
Rear control arm/suspension set:
4 Control arm bushing’s
4 Sleeve’s
12 Various arms bushing
12 Sleeve
4 yellow grease tubs
1 Instruction sheet
Rear sway bar bushing set:
2 15mm sway bar bushing
6 Bar/frame endlink bushing
2 Upper frame endlink bushing
1 grease
1 Instruction sheet
***HICAS equiped cars (or just the HICAS rear bar). You have two options, you can either drill out the 15mm bushing that they send you in the kit to the required 22mm, or for an added cost you can buy a universal kit that will come with the 2 bushings and mounting brackets (you will need to use the regular end link bushings that come in the kit.
Rear subframe inserts set:
2 Front position inserts
2 Rear position inserts
4 Washer
1 Instruction sheet
S14
Rear End Control Arm Bushing Set…PM 4 details
Front Sway Bar Bushing Set 27mm…$45.00
Rear Sway Bar Bushing Set 16mm…$40.00
Front Strut Rod Bushing Set …$70.00
Tie Rod Boots …$15.00
Hyper Flex Complete Master Bushing Set…$150.00
2 - bushing.
2 - sleeve
2 - inner bushing.
4 - outer bushing.
2 - sleeve
4 - grease.
2 - bushing.
2 - grease.
Front sway bar and end link bushing set:
2 - sway bar bushing (27mm dia. bar)
2 - bracket.
2 - washer
2 - spacer
2 - bolt
2 - end link bushing.
Rear control arm bushing set:
2 - toe link bushings.
4 - lower control arm bushings.
6 - sleeve
10 - control arm bushings.
10 - sleeve
4 - grease.
1 - installation instruction.
1 - sway bar tape measure.
Rear sway bar and end link bushing set:
2 - sway bar bushing. (16mm dia. bar)
2 - mini bracket.
4 - end link bushing.
1 - grease.
Tie-rod boot set:
2 - tie-rod boot.
1 - grease.
Note: The S14 kit does not include the subframe insert kit so, by request, I will include it for $35 extra.
Any questions don’t hesitate to PM or EMail
