Hi guys,
I just found a really good deal for some winter rims and tires…was wondering if they will fit on a 2007 350z with the Brembo Brake Package.
Here are the specs: Winter TOYO tires 215/ 55R17 (5x114.3 bolt) on MOTEGI Racing Rims
Thanks!!!
Hi guys,
Thanks!!!
whats the rim size?
Go here and check against the oem tire size. You cannot be more then 3% from oem diameter.
its the rim size thats the problem right?? not the tire size?
The rim size is 17"X7…any thoughts?
Top figures are for: 235/55/18 front tires. Bottom figures are for the 215/55/17. My back tires are 255/55/19. Not sure about the middle number though. Any thoughts?
Section Width: 9.25 in 235 mm
Section Width: 8.46 in 215 mm
Rim Diameter: 18 in 457.2 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 6.5 - 8.5 in
Rim Width Range: 6 - 7.5 in
Overall Diameter: 28.17 in 715.51 mm
Overall Diameter: 26.31 in 668.27 mm
Sidewall Height: 5.08 in 129.03 mm
Sidewall Height: 4.65 in 118.11 mm
Radius: 14.08 in 357.63 mm
Radius: 13.15 in 334.01 mm
Circumference: 88.49 in 2247.6 mm
Circumference: 82.65 in 2099.3 mm
Revs per Mile: 738.3
Revs per Mile: 790.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 64.2 mph 107. km/h
Speedometer Difference: - Speedometer Difference: 7.070% too fast
Diameter Difference: -
There’s a guy who is trying to sell me a similar rim tire combo and he says it most definately fits brembo brakes…These are the specs…and they are very similar to those that i had posted…It’s a package he’s designed specifically for Brembo’s.
This is the package: $1,180.00 BREMBO Cars will get the following:
4 x 17x8 ADR (HUBCENTRIC) 66.1 +24
4 x 215/55/17 Hankook W409 iPike Snow tires
4 x Mount and Balance - With FREE DELIVERY IN THE GTA
My question is, if he says that those will fit the car perfectly, why wouldn’t the ones I’ve asked you about…
Sorry if my questions sound dumb. I’m trying to do research that’s why im asking you these questions.
and he specializes in rims and tires…its a store
+24 offset will most likely clear the brembos. It’s the tire sizes that i’m not 100% on. but it’s winter time, so it doesn’t matter as much.
I have a friend running 17’s without problems. I forget the tire sizes though. Even with VDC, when the tires are equal size it won’t throw the slip light on that much (if at all). Again, my buddy’s running same size (iirc) all around.
get it from tirerack.com ~
