are these tires compatible with 350z?
i found a good deal on winter tires size: 225/55/17" - says they fit brembo brakes.
will somebody please tell me if these will fit on my car? - the current tires are 235/50/17".
awesome…thanks! "D
Hi Lady z,
You should really do some research with regard to the 350z. I would suggest searching through www.my350z.com, in order to gain a better grasp of what will work for you.
Know that you should not go beyond 3% of the original diameter, or your vdc will go into “limp mode”.
If you are going to look for tires, use this tires size calculator to check if the size will fit without throwing any errors at you.
Good luck
