Where did it break on the bolt/nut Phil? On both of mine, it broke at the
tip because the washer was seized with the nut so turning the nut just
twisted the bolt tip.
Lucky for you it’s in the weekday. I had to wait through the weekend and
long weekend holiday.
BTW, Are you going to prep it in some way to avoid future rust? I mean I
doubt any rust in the next few years will affect it (considering two of mine
survived even after 12yrs). But it doesn’t hurt to prep.
I just dabbed a crap load of grease all over the nut.
If you’re planning on keeping the car, and doing another allignment in the future, just keep the new bolts/nuts as they are.
Shit, I forget what that gel is called, but instead of putting locktite or anti-seize, there’s a special gel (I’ll try to find out the name tomorrow) that’ll keep moisture out and prevent the bolt to seize. Just found out about it the other day, used it when I replaced my spark plugs. Supposed to work real good… but I guess only time will tell.
