help im at the junk yard
will 1990 300zx wheel hubs fit on a 89 240sx. and also i have 95 240 5 bolt rims and kno that the stock tire size is 205-60-16 but what size will work on the 89 smaller side wall?
only the rears will and only if its non turbo 300zx
check your pm please
y not the front
WTF ?!
Because they don’t fit! The front of the car is different from the rear in case you did not notice.
The front hubs are too big in diameter…its only about a MM off on either side, but it doesn’t work. The bearing/hub assembly bolts right up on the back though.
got boost whats ur deal man
