I need an iphone cable like this:
iphone to both -
- female headphone size line out (line level preferred, but not needed)
- USB or cigarette lighter
and I want it cheap.
anybody?
edit: like this, but with USB (not firewire)
iphone to both -
anybody?
If you find such a thing I’d be interested too. Right now in the car I run one cable from the headphone out to my line in on the stereo plus a 2nd cable from the dock connector to my cigarette lighter USB adapter for charging.
EDIT: I assume what you’re trying to do is get both the line out and the charging off the dock connector with one cable right?
I have the charger that goes from cigarette lighter to the Iphone/iPod connector. It complains that it isn’t compatible with the iPhone but still chargers it.
And do you want a standard 1/8" to 1/8" cable or the Iphone/iPod connector to 1/8" (which doesn’t make sense)
<EDIT ALSO>
Not sure if that would work…looks like an iPhone/iPod connector to 2 angled 1/8" jacks and a USB
YES, you have the same exact problem as me. I just want to clean up all the wires in my car and simplify plugging my iphone in.
I hacked my stock BMW radio to have a line in instead of a tape player. Now when I hit “Tape” it uses a hardwired line-in that I added.
good find… somebody in the USA (or hong kong) must be selling this?
Yeah, probably if you search hard enough. That was the only result I got on ebay using search terms “iphone USB line in”. I’m guessing the same cable is probably on ebay with other sellers though, it’s just a matter of sifting through the mountain of results you get when you search for “iphone USB”.
I asked this guy a question since his listing sucks:
Looks like it’s probably cheaply made, but hey it’s 5 bucks…
I’m surprised that an analog signal (for the 3.5mm stereo connector) comes out of that bottom connector…
EDIT: Sure enough. Pins 3 & 4.
http://pinouts.ru/PortableDevices/ipod_pinout.shtml
Ya check Monoprice or something. I have a quazi setup like this. I have this http://www.griffintechnology.com/products/roadtrip-with-smartscan-2008 and then out the bottom is a line out that can plug into my aux in on my car. Little more expensive but nice to hold the phone where I can touch it without it sliding all around my car.
this guy got back to me and says it’s exactly what I needed so I ordered one up.
the DAC in the iphone is surprisingly good, better than most car head units so analog out is ideal
