I could have sworn a long time ago I knew where to buy needles for an instrument cluster. The should be the illuminated lexan kind…
Anyone dig up a link?
I have been googling around with no great result…
I found these, but not exactly what I am looking for:
If your needles already light up can strip the paint off and re-use? If not, I would try to get some GM needles to work with. Most of them are clear with an orange/red paint that can be taken off rather easily. I remember seeing clear needles on Ebay a while back but not so much luck now. :shrug:
This place sells kits to light the needles but does not include the actual needles.
http://www.importcarpartsplus.com/Needles.htm
Same Here:
http://www.autoaccessorystore.com/home_n.asp?dir=detail&id=729
Yeah, I’d rather not have to raid JYs, but I will…
I plan on hitting M&M next week as I am off from Work. I can grab some for you if you know what you need. LMK.
I need ones that are about 1.5" from center to tip.
They also need to fit over a 3/32 pivot pin. But I can probably adjust that.
I will take a look and get back to you next week.
hammer and a sandwich bag, go to m n m and smash some clusters take a hand full
