Anyone know anywhere around here that sells nuts like these?
I need them with a m12x1.25 thread. 30mm high, 17mm diameter on the cylindrical portion.
They are for my camber plates.
Try Douglas Industrial in Watervliet or Fastenal on Broadway
From the manufacture of your camber plates, or via one off machined parts. They are coupler nuts, turned down in a lathe to the neck diameter requirements.
Yes I can do it
Or you can buy cylindrical coupler nuts of proper thread, machine to required diam, tig on hex nut for assembly.
I may have some of these around my garage. No sure of size and pitch but ill check if i come across them easily
PMed you again
These are a proprietary nut, not something you’re going to find in a hardware store. The camber plate manufacturer will make their own based on the spherical bearing and strut rod dimensions.
