Hershey Canada Issues Voluntary Recall Of Several Products
Sunday November 12, 2006
Chocolate lovers and bakers will want to scan their cupboards after Hershey Canada issued a voluntary recall of a number of products Sunday.
The chocolate company is pulling a wide range of items from chocolate chips to candy bars from shelves due to possible salmonella contamination of products made at its Smiths Falls plant between Oct. 15 and Nov. 10.
Symptoms of salmonella can include, nausea, vomiting, stomach cramps, diarrhea, and fever.
There have been no reports of illness in connection to the confections so far and Hershey Canada says it’s working in conjunction with the Canadian Food Inspection Agency to ensure its product is safe. None of the recalled products were produced for Halloween.or Christmas treats.
Here’s a look at the affected products:
*Only the date codes starting with four digits ranging from 6417 to 6455 of the following products are included in the recall. The date codes can be found on the back of each unit.
Hershey Chipits Milk Chocolate Chips - 270 gram
Hershey’s Creamy Milk Chocolate with Almonds - 43 gram
Hershey’s Creamy Milk Chocolate - 45 gram
Oh Henry! - 62.5 gram/62.5 gram 4 bars/145 gram
Oh Henry! Bites - 130 gram
Oh Henry! Peanut Butter - 60 gram
Hershey Chipits Semi-Sweet Chocolate Chips - 350gram/2kg
Hershey Chipits mini chocolate chips - 300 gram/10kg/175 gram/500 gram
Hershey Chipits Chocolate Chip Bulk - 10kg
Hershey Chipits Semi-Sweet Mint Chocolate Chips - 300 gram
Hershey Semi-Sweet Chocolate Chips - 300 gram
Hershey’s Special Dark Chocolate - 45 gram
Hershey’s Special Dark Chocolate with Almonds - 43 gram
Reese Peanut Butter Cups - 51 gram/68 gram/51gram - 4 bars
Lowney Cherry Blossom - 45 gram
Glosette Peanuts - 45 gram
Glosette Almond - 42 gram
Glosette Raisin - 50 gram/145 gram
Hershey’s Chocolate Shell Topping - 177ml
Eat More Dark Toffee Peanut Chew - 56 gram/ 56 gram-4bars
Lowney Bridge Mix - 52 gram/340 gram
Hershey Assorted 16 Count - 728 gram
Hershey Assorted 50 count - 2.5 kg
Nut Roll - 5kg
Hershey Semi-Sweet Chocolate Chips - 10kg
If you have any questions about the recall, call Hershey Consumer Relations at 1-800-468-1714.
Hershey Canada
