Coming into winter and the end of the year the cost on HID’s has been dropped from the Distributor so I can pass it along to my end consumers.
HID Conversion Kits: Starting at $80 including tax and shipping charges.
Size Options:
H1
H3
H4(9003)
H4 (9003) High/Low: +$25
H7
H8
H10 (9005)
H11 (H9): +$5
H13
H13 High/Low: +$25
9006
9007 (9004)
9007 (9004) High/Low: +$25
880 (899)
881
[COLOR=Red]D2C (D2R, D2S): +$10
[COLOR=Black][COLOR=Black]Bulb Color Options:
3000K: +$5
4300K
6000K
8000K
10000K: +$5
12000K: +$5
[COLOR=Black]Warranty Options:
1 Year Warranty: Free
[COLOR=Red]2 Year Warranty: +$25
[/COLOR][COLOR=Red]Lifetime Warranty: +$45
Relay Harness: Add +$15
[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]Features
-Lower Power Consumption
-3 Times Brighter
-Increase Life Span
-1 Year Warranty
-Less than 0.5% defect rate
-Waterproof
-Shockproof
-Most are 100% Plug and Play
Kit Includes: (2) Bulbs, (2) Ballasts, (1) Installation Manual, Mounting Hardware & Wires
BEFORE AFTER
Product Details
HID conversion kits are custom engineered and built to endure the most extreme impact and temperature conditions that may occur during off roading, rallying or daily driving. Each component is hand picked and custom designed to reduce the flaw rate down to 0.5%. Not only are the components individually picked, the components double reinforced to insure that there are no sudden surges that may damage the vehicle or the kit. When engineering these kits, we keep in mind that lighting is the most important function needed at night, therefore we use the highest quality materials to create an HID xenon system that will not fail when needed. Our HID conversion kit is mostly composed of Japanese derived components, a few other minor components come from Germany & China. The simplicity of our design allows even people without prior knowledge of HID installation to be able to complete the installation within 10-20 minutes.
The kits are waterproof and shockproof, we’ve submerged them underwater in a pressurized tank for hours to insure the results are true. All components of the kit come with a standard 1-year warranty, this covers everything from minor defects to factory defects. Additional warranty can be added when choosing options for your kit.
Xenon HID: State-of-the-Art Lighting Technology
Xenon HID lights are the brilliant, blue/white lights that first appeared on luxury and high performance cars and are now becoming available on an entire range of cars, trucks and SUVs. HID lights provide twice the light of conventional halogen lights for the ultimate in driving safety.
200% more light = earlier recognition of road hazards
With twice the amount of light you can see potential obstacles much sooner. At highway speeds, HID lights give you up to a full second more time to safely react to road hazards.
Better reflection of road signs and markings = safer driving
Even in bad weather, Xenon lights help you see what is ahead, sooner and better. They improve your view of road signs, other vehicles, intersections, and objects on the road. Daylight white light = relaxed driving Compared to the yellowish light from conventional lights, Xenon bright white light is much closer to natural daylight. This helps reduce the eye fatigue normally experienced when driving long distances at night.
[COLOR=Red][COLOR=Black][COLOR=Red]
[/COLOR][/COLOR][/COLOR]Technical Specs
[LEFT]Size of ballast: L88 x W75 x H32mm[/LEFT]
[LEFT]Input voltage: 9~32V[/LEFT]
[LEFT]Rated voltage: 13.5V[/LEFT]
[LEFT]Max start voltage: 23kv[/LEFT]
[LEFT]Max input current: 3.2A[/LEFT]
[LEFT]Output power: 35W[/LEFT]
[LEFT]Working Temperature: -40 degrees to +105 degrees[/LEFT]
[LEFT]Power efficiency: reach 83%[/LEFT]
[LEFT]Working Frequency: 260~310 Hz[/LEFT]
[LEFT]Lifetime of ballast: 3500 hours[/LEFT]
[LEFT]Lifetime of bulbs: 2500+ hours
PM me for orders or questions
[/LEFT]
