[SIZE=6][SIZE=7][COLOR=darkslateblue]HID Conversion kit with Relay Harness, 2 Years Warranty … from $120 !!![/SIZE][/COLOR]
Not a Group Buy !!!
[COLOR=Magenta]Pick one up today HIDs are always in stock !!![/COLOR]
[/SIZE]
Please Contact:
[SIZE=4][COLOR=black]PM or [/COLOR][/SIZE][SIZE=4][COLOR=black]the.hid.lighting@gmail.com
[/COLOR][/SIZE]
What is inside:
[SIZE=4]Original HID Conversion Kit — The affordable lighting solution.
[/SIZE]2 Original ballasts, 2 HID light bulbs, relay harness, mounting brackets, bolts, installation guide
[SIZE=4]Slim Digital Chip Ballast HID Conversion Kit — It’s slim. It’s light. It’s digital.
[/SIZE][SIZE=4]2 Slim Digital ballasts, 2 HID light bulbs, relay harness, cable ties, installation guide[/SIZE]
Warranty:
[SIZE=4]2 Years Direct Warranty by us - direct replacement from our side. — warranty cover bulb, ballast and even relay harness[/SIZE]
Cars with our HID:
http://picasaweb.google.com/the.hid.lighting/CarsWithOurHID
Pricing :
[SIZE=4]Original HID Conversion Kit with relay harness
[/SIZE]
- $120 — Single Low Beam — H1, H3, H4, H7, H8, H9, H10, H11, H13, 9003, 9004, 9005, 9006, 9007
- $125 — H4, 9003, 9004, 9007 2 Bulb — HID bulb for Low Beam and Halogen Bulb for Hi Beam/ DRL
- $130 — D2S, D2R
- $155 — Hi/Lo Bi Xenon H4, 9003, 9004, 9007 — mechanical Hi/Lo Kits that can operates as a high, or low beamSlim Digital Ballast HID Conversion Kit with relay harness
- $150 — Single Low Beam — H1, H3, H4, H7, H8, H9, H10, H11, H13, 9003, 9004, 9005, 9006, 9007
- $155 — H4, H13, 9003, 9004, 9007, 9008 2 Bulb — HID bulb for Low Beam and Halogen Bulb for Hi Beam/ DRL
- $160 — D2S, D2R
- $185 — Hi/Lo Bi Xenon H4, 9003, 9004, 9007 — mechanical Hi/Lo Kits that can operates as a high, or low beam[SIZE=4]Original HID Ballast
[/SIZE] - $80 a pair, add $5 for brackets and bolts Slim Digital HID Ballast
- $115 [COLOR=black]a pair[/COLOR][SIZE=4]35w HID Bulb
[/SIZE] - $45 — Single Low Beam — H1, H3, H4, H7, H8, H9, H10, H11, H13, 9003, 9004, 9005, 9006, 9007
- $55 — H4, H13, 9003, 9004, 9007, 9008 2 Bulb — HID bulb for Low Beam and Halogen Bulb for Hi Beam/ DRL
- $60 — D2S, D2R
- $85 — Hi/Lo Bi Xenon H4, 9003, 9004, 9007 — mechanical Hi/Lo Kits that can operates as a high, or low beamRelay Harness
- $20Color Temperature:
[SIZE=4]3000k (Yellow), 4300k (Sun White), 6000k (Diamond White), 8000k (Blue White)[/SIZE]
[SIZE=3]3000k add $5 and only available for all single low beam and H4/9003 2 bulb.
No 3000k for 9004 2 bulb and 9007 2 bulb.
No 3000k for all Bi Xenon bulb.
[/SIZE]Check your bulb sizes:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/default.htm
FAQ:
Q: Are the HID weather and shock proof?
A: Yes all HIDs are weather and stock proof.
Q: Are they plug and play?
A: Yes all easy plug and play.
Q: What is Relay Harness?
A: Relay Harness is an extra wiring harness for the HID kit providing extra fuse box to protect both the HID system and other electronic on the car. The relay harness has diode inside to protect back flow current. If your car has any sudden current change the relay harness fuse will burn out instead of hurting the the HID system’s bulbs or ballasts. The relay harness can fix most of the flicking problem. Our HID kits can be installed without the relay harness also.
Q: Why no 10000k and 12000k on your post?
A: 10000k and 12000k it not street legal. The color will attract the cops to pull you over. Plus these 2 color have low lumen = not bright enough (as color temperature increase brightness decrease). But by the way we can still get them contact us for detail.
Q: How will the Day Time Running Light (DRL) function after change to HID system?
A: If your car is using low beam as DRL also, the HID will be on even DRL current go through the HID ballast. The HID system do not have dimmer light output so you will have to turn the HID on all day long. Some customers do not mind turning HID on all day (Since HID bulb has 3000+ hour life). Some customers will do some re-wiring on the DRL to change the DRL to the fog light or signal light. Some 9004 and 9007 plug might need to switch the wire in side the plug which connecting to the car to make the HID work but it is just easy mollification. 2 bulb will have no DRL problem as the extra Hi beam halogen bulb will provide the DRL.
Q: Why buying Slim Digital HID kit?
A: Even though the Original HID kit is a very good lighting solution already, the Slim Digital HID Kit have 2 extra selling points to customers: 1) the ballast is very slim & light and good for tight engine bay 2) it includes digital ballasts which have ‘brain’ inside and will be continually monitoring and checking the input and output voltage and current to maximize bulb life, color and illumination (brightness).
Q: Do you guys do installation?
A: We do not handle installation, but we have buddies doing HID installation from $50. PM us for details.
[SIZE=6][COLOR=darkorange]Thank you for all interest & support
[/COLOR][/SIZE]
