What Do you guys recommend doing for higher speed cars, suspension wise? Is there anything I can buy that will make the car more stable in the front and rear with out losing reliability for street driving?
lead weights in all four corners will in fact give the car more stability…you will feel like you are in the pavement.
cement in the trunk to keep the rear end down at high speeds.
edit- mixed of courseyou want it to evenly be spread around the trunk. try to get some tarps or something so its not so messy when its still wet
So what did you do to the motor? I thought it was a mostly stock 5.0
it is, i only mean like 120 but the 95 mustang is really scary at that speed i just want to make its so its not soo loose on the road
Do all the bushings in the suspension.
Have an alignment done.
have all your tires and wheels re balanced
tighten anything that rattles.
edit/ also maybe consider lowering it and going with wider front and rear tires.
^^^and to this its all ready done
huge wing will help
lol.
my foxes feel fine up to 120 but around 130 or so I get a bit scurred
yea same
Is that the mustard with the tiger painted on it?
i think so
Mustard with tiger for everyone that doesn’t know what it looks like.
why did that win a prize?
^^^HAHAHAHA
I had to do it, other one could be:
WNY’s Most Noticed…
… By the Police
lmao
