All prices are OBO and negotiable within reason. Shipping & paypal fees not included.
I am located in Olean NY 14760
MBC -175
LS Block -100
Stock GSR valve springs -5
Stock ITR outer valve springs -25
Miscellaneous GSR head parts -25
Cam gears -20
GSR head bolts -20 (3 sets)
LS main cap bolts -10
Stock GSR pistons/ rods -25 (2 sets)
GSR bare Block - Bored .020 over (81.5mm) -200
GSR flywheel -25
GSR stock clutch and pressure plate -20
LS oil pan-25
Box of parts - oil cooler, canisters -10
GSR oil pick up -20
6 Gauge holder -20
Stock GSR Throttle body -65
Dash insert with two gauges -20
Boost Gauge 30vac-20psi -30
Boost Gauge 30vac-30psi bent -20
B-Series Starter - needs a rebuild -20
20 Stock size wheels studs -5
Shift light -25
Clutch master cylinder -25
Stock civic brake booster -25
10" Auto meter tachometer -100
DC sport short shifter -45
Stock shifter -10
Civic hub set -25
Shifter bushing kit -15
94 stock Civic corners -20
Head lights, I think they are from a 2nd Gen civic? -40
Proportioning valve -10
Thermo housing -10
1 LS, 1 GSR, 1 B16 coolant -10 each
GSR oil jets -10
GSR oil pick up -10
GSR used oil pump -20
GSR baffle plate -20
Honda no name rear upper strut brace -$75 obo
Came out of my 94 Civic hatch
Wont clear the roll bar
Civic 92-95 front knuckles, new bearing, extended wheel studs, new ball joints, discs and pads have less then 200 miles
