Loc: 10954, NY
Contact: todaparty@gmail.com
I am moving away to Vegas for school in JULY. ALL this stuff must go by then. Throw me reasonable OFFERS, not lowballs. I have pics of some of the stuff but my digicam is broken right now. I can get and send directly to you from my Iphone tho, just PM me ur email address. Some Pics are LINKED, look under the description for the link to click to see the pic.
SOLD STUFF
1997 Type R ECU (OBD2A) to pass inspection/emissions in 96 and 97 cars with boosted setups – the 98 ITR ECU throws emissions CELS when not used in a car with integra emissions control devices, so this is very rare and the only ITR ECU that will work in this regard. Yes you can use a GSR OBD2A manifold, but I’m not sure if you will throw a code for the butterfly valves…this ITR ECU will work for GSR motors using non-GSR intake manifolds (skunk2, edlebrock, etc). - SOLD
hondata thermal intake manifold gasket, GSR - SOLD
RC 550 cc injectors, saturated. Work fine. SOLD
Still up for grabs
OBD 1 GSR long block - The motor has about 70K on it
The head was sent to CC Cylinder heads and has a street port with ITR valvesprings & retainers, gsr cams, skunk2 intake manifold. I have both an OBD1 distributor, and OBD2 distributor (incomplete) so depending on if ur swapping into OBD 1 or 2, u can choose the distributor u need. OEM GSR throttlebody included. Also have freshly cleaned and flow tested (by Cruzin Performance) OEM 240cc HONDA injectors sealed in in the bag to go with the head, as well as an OEM rail with oem regulator.
Asking only $650 – headwork alone was $350
- The block is still stock, and I started to tear it down but stopped…The mains, crank and pistons are untouched, but I took off the oil pain, windage, pickup, and the various hoses and brackets on the outside…everything’s labeled and in bags. I also have a set of 82mm RS Machines OEM PR3 replica cast pistons w/ new rings that I can include in the deal.
- $600 for block w/ RS machines pistons
- $500 for the block w/o pistons
$1150 for everything - I will give you an OEM Honda headgasket if you buy everything (head, block, pistons)
$1050 for everything minus RS machines pistons(no headgasket).
Pic of head is BEFORE head work - the valves are all clean now.
Heres the 2 distributors that will be included. Swap the insides to one or the other.
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=distributors.jpg -
And the BNIB Headgasket
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=hgasket.jpg
RS Machines 82.0mm PR3 (B16) Pistons - $160 - Roughly low 11:1 with a 87.2mm crank and b16/itr head, ~11.5:1 with GSR head with 87.2mm crank. Comes with new rings, wrist pins, and a moly coating on the skirts. These are 180+shipping from RS Machines (ebay).
ITR Rods - $160 30k miles on them. Mint condition, were replaced with forged stuff for a boosted setup. Stronger than GSR rods, lighter than Eagle rods – great for an all motor setup or mild boost.
Garrett GT2871R with .63 a/r exhaust. Comes with an edlebrock B-series manifold, all water & oil lines, fiittings, etc. Mint condition, no shaft play, no busted oil seals, no blown bearings. Just can’t have a turbo car and be in school at the same time, cuz I’d fail school for sure. Asking $1000 obo for it all.
BNIB w/o the box Type R throttle cable and bracket for EK to B swaps - $50
3" stainless downpipe with 5-bolt T3 flange and flex pipe(will need to be modifed to fit the above turbo/manifold combo) - $150
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=3dp.jpg -
Shaved OEM Bseries crank pulley professionally done by http://www.hondamarketplace.com/showthread.php?t=2448247 (PS part shaved off, since my car is a CX, I planned to use it on the swap…) - $75
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=crank1.jpg
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=crank2.jpg -
OBD1 P75 converted to P28, chipped etc – ready for the BNIB DEMON board to be installed. Used to be on Neptune, upgraded to Demon. It is uninstalled however – $350
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=demon.jpg -
GM BOSCH water pump for air to water intercooler setups. These are the same ones frozenboost.com sells for 120 – asking $85
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=boschpump.jpg -
Walbro 255lph high pressure fuel pump DC/EG/EK $80
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=walbro.jpg -
Bseries shift linkage - $60
CRV AC bracket - used to keep the D-series AC Compressor when swapping in a B-series motor. BNIB - $120
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=crvbrack.jpg -
Vortech Adjustable FPR - have 1 purple, 1 blue - $40 each
Si rear engine bracket for swapping B-series into EK’s - $80
ACT Streetlite 12.5 lb Bseries flywheel - used 5000 miles, no heat scars, no divots or anything like that - $160
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=actfly.jpg -
ONE HAsport B-series EG/DC driver’s side mount, 80A i think I can’t find the other 2 mounts for the life of me…$75
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=hasport.jpg -
97 civic EX Vtec harness - used for VTEC bseries swaps in your non-vtec civic, comes with obd2 and obd1 clips - $150
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=civicharness.jpg -
Beaks EG/DC subframe reinforcement kit for rear swaybars - $50
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=beaks.jpg -
Civic Si Rear Tbracket for Bseries swaps - $50
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=eksiT.jpg
Civic Si Brake Booster - $70
Civic Si 4 wheel disc proportioning valve FOR EK ONLY- $50
AEM 2.5” short ram tube- $40 - Bracket is cut off. No filter. Couple scratches.
DC/EG 19mm rear sway bar - $50 - I believe its a suspension techniques, but don’t quote me. Comes w/ the bushings for the subframe, but no end links.
Phillips D2R HID bulbs & 03 Maxima ballasts - $100, will not sell just one unless you find someone to take the other.
Honda centercaps $30 – Rota ARE SOLD. – Hcaps are P/N 44732-S0X-A00
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000862.jpg
Compustar Alarm w/ Remote - $50 – Just the remote and the brain.
OBD2a (97)LS intake manifold w/ AIT & IACV(not in pic, will include) - $ 40
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000837.jpg
OBD2a (97)LS Water Neck (back of the block)- $15 shipped
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000849.jpg
OBD2a (97)LS Thermostat housing - $40 - thermostat, coolant sensor included
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000846.jpg
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000847.jpg
OBD2a (97)LS timing belt cover - $20
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000859.jpg
LS alternator belt - $ 10 - good condition, about 15k miles
http://smg.photobucket.com/albums/v320/todaparty/Garage%20Sale/?action=view¤t=P1000851.jpg
3” Exhaust 3 bolt flange- $15 – I cut it off so I could run an exhaust clamp. Its off a Lovefab 3” exhaust.
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000865.jpg
90 Degree mandrel bend intercooler pipe 2.5” - $25 - bead welds on the ends for sealing. Mild steel, 2.5”.
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000867.jpg
Stock EG Hatch DX Upper Control Arms Make Offer
http://img.photobucket.com/albums/v320/todaparty/Garage%20Sale/P1000616.jpg
