Honda OBD2a to OBD1 jumper harness question
what else is needed to run the obd2a-obd1 jumper harness?
obviously a obd1 ecu
distributor?
injectors?
i have the 96 civic w/ a OBD2 engine and i plan on boosting it ( i know i wont pass inspection).
any info would be great
im pretty sure your just going to need the harnesss.
all i needed on my si was a harness and an ecu.the dizzy is stock…
im unsure of injectors.you will have to change the clips depending on brand
im using dsm 450 injectors
im pretty sure your going to need to use the dsm clips in your stock harness…
im pretty sure…
you’ll need obd-I injector clips and a resistor box wired in to raise the impedance to the injectors. That is all.
shit your right i forgot about that,scspeed has a resistor box for sale…
J-K-Tuning.com has the jumper harness…do you have the resister box for the injectors? i didnt have to change any clips on my car but i did have to trim down the o ring since the dsm injectors are a little bit bigger that honda injectors i just used a razor blade and some bloody fingers to get them to fit in right
edit: wiring for resistor box http://honda-tech.com/zerothread?id=517274
