ok my car is fucked
and i wanna make sure my ecu is ok
so i want to test it on someone elses 240
i live in brampton
let me know if u wanna try my jim wolf ecu on ur stock ka lol
ok my car is fucked
i live in brampton
i have a ka-t i will let you run yours in mine if you need it? but i have z32 and 370s i dont know what your steup is. im in london
its tuned for z32 maf and 550cc injectors
i live in brampton… but my car is at the body shop…stock KA24DE… if you still need it in a couple weeks… let me know!
do you still need to test it? i will have my 550’s in next weekend
yes i do
ok ill let you know when its in and running, then we can throw your ecu in and see if it works, did you check the power to the fues box, the big black wire? also did you try to scan it using a scan tool? what did it say if you did? if it said no communication then it is likely there is a bad fuse, as the ecu steals power from other things, (we have this problem alot at my dads shop) what does the car do/ not do?
all the fuses are good…
its like there is no accesory at all. no fuel pump, no safc, no spark. no ecu
it will just crank over but nothing will happen
i know the fuses may be god upon visual inspection but do they have power to them? if you havent done so aldreay test them with a test light, each little silver dot on top of each fuse should have power(light up) let me know what happens
