I just did a z6 head swap on a b7 block. While doing the swap i decided to go and put a Skunk2 intake manifold on. Well since the runners are longer the IAC valve hits a brake line splitter on the fire wall. I was told there is a relocator for just this type of situation. I cant find anything on it. Maybe with a few collective minds i can find it. Thanx guys
I have seen it once, it is basiclaly a plate with barb fittings for vacuum lines. However you need to run coolant to it also whereever you put it.
