Selling my WRX/STI innovative stage 2 block 125-133 for compression shortblock is in perfect condition
The rotating assembly is balanced to a quarter of a gram at 10,000 rpm or better to ensure smooth operation abd CNC bore and hone are performed using Subaru specific deck plates. All clearances are carefully checked and adjusted as necessary to extremely exacting tolerances well beyond factory blueprinting. The new block halves are checked for true and surfaced to a finish beyond the requirements of MLS gaskets.
This shortblock is recommended for 600 crank HP, 8000 rpm, and 27 psi
Retail: $4,250
Looking for $3,250
4,000 miles used
BRAND NEW OEM 703 casting 2.5L STi block halves
-CP Forged Pistons upgraded rings and pins
-Eagle ESP Forged Connecting Rods with ARP hardware
Then why didn’t you state that.
Parts like this usually a reason for the sale is very welcome.
Helps at least imply there is nothing wrong with the item for sale.
