can you boys recommend a few shops in Toronto? If you have a phone # that would be great.
cheers!
cheers!
Is this KA->SR?
or KA(E)->KA(DE)?
or KA->CA?
Either way, i’d recommend getting some people over from the board with an engine lift and working on it yourself.
The experience would be well beyond worthwhile, and many of the members have in fact worked on swaps/did their own.
This is a s15 swap into a factory usdm NA 240.
maybe avery will…
im sorry but i would not touch that with a 10 foot pole
S15 swap… wow, good luck with the wiring…
Among other things…
You’d have to use that 10ft pole to custom fab a driveshaft.
You’d have to use that 10ft pole to custom fab a driveshaft.[/quote]
LMFAO!!! Good Call dude, Good Call… ![]()
Look up Absolute Motorsports in Brampton. You will need to find a shop that makes custom driveshafts. Wiring is the hardest part, but dropping it in the bay should be a snap.
If it were warmer out or I had a place indoor to do the work I would gladly take on the challenge. It would not be a weekend job though and i would need a s15 service manual. I know of a few places in my area that fabricate drive shafts. Absolute might not take the job because it is not a 300zx or a 350zx. They only like to work on those cars and are quite snobish about it in my apionion.
Velocity in Markham has done it, but it cost a pretty penny…are you putting in the 6 speed as well?
You can try Whitehead Performance.
