I’m trying to get this site to run and obviously Java is being a POS
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/experiment/lowpass/lpf.html
I’ve updated java and added that site (both the full address and up to .uk/) to the ‘edit site list’ on the Java control panel.
Anything else I can do to get the java application to work?
Based on that website, I am assuming this needs Java 6 to bypass a lot of new security measures.
http://www.oracle.com/technetwork/java/javase/downloads/java-archive-downloads-javase6-419409.html#jre-6u45-oth-JPR
You probably need to over ride the self signed applet restriction just a guess
What browser. If it’s Chrome, you’ll need to enable Java controls in the address bar. If IE there are two different versions of Java based on bitness so if you’re using the 64-bit IE you need the 64-bit Java. Firefox I’m not sure.
Also, Fuck Java
