:thumbupfirst off sorry about the caps lock but thats how i put it on ebay and didnt feel like retyping everything so just copied and pasted…
400.00 bucks
Complete ls vtec conversion…
JDM TYPE R B16 VTEC HEAD
B17 CAMS,GEARS,AND INTAKE MANIFOLD.
B16 VTEC VALVE COVER
B16 OBD DISTRIBUTOR
SHAKO OIL FEED LINE
LS THROTTLE BODY…
B16 OEM HEAD STUDS.
VTEC SYLONOID
THIS IS A COMPLETE SETUP ALL YOU WILL NEED IS A HEAD GASKET THROTTLE BODY GASKET AND VALVE COVER GASKET…THIS IS A JDM B16 HEAD VERY HARD TO FIND AND THE BEST OF THE b16 VTEC HEADS…PICTURES SHOW THE CHINESE IMPRINTS ON THE SIDE OF THE HEAD AND YOU CAN ALSO TELL BY THE SHAPE OF THE CAM GEAR RAILS…THE HEAD IS COMPLETE WITH CAMS GEARS CAM HOLDER ECT…I HAD THE OIL FEED LINE MADE AT SHAKO SO IT WILL TAP RIGHT INTO THE OIL PRESSURE SPOT OF THE BLOCK AND STILL HAS A INLET FOR THE SWITCH…I ALSO HAD THE HEAD LOOKED AT AND ACID WASHED BY A LOCAL MACHINE SHOP (SAID IT LOOKS GREAT)…ONE OF THE DISTRIBUTOR MOUNTS ON THE HEAD SNAPPED OFF BUT THERE ARE STILL TWO MORE TO HOLD IT ON AND THE MACHINE SHOP SAID IT WOULD BE FINE…ALSO THE GREEN SENSOR ON THE VTEC SYLONOID HAS A CRACKED CASING BUT STILL PLUGS IN FINE AND WORKS FINE…TWO EASY FIXES…IF YOUR LOOKING TO GO LSVTEC OR REPLACE YOUR HEAD THIS IS THE U
Uploaded with ImageShack.us
Holly smokes those pics are big how do i resize them?
WOW MY EYES HURT NOW!!
U should be able to do it rite through the site if imageshack is anything like photobucket that is… If not get urself a photobucket account n try again!
Figured it out thanks OG…
i have a completly rebuilt ls block ill throw in for another 200…
some good deals in here
I know a few weeks ago i was looking for a deal like this…now i have more b series shit then i know what to do with…did i mention trades considered
trade for a d16a6?:lol
Hmmm ill have to think about this one…
SYLONOID…
you need one?
you spelled that so wrong it made me laugh till i cried. it reminds me of when people say cadillac converter.
MY b “solenoid”
SOLD!!!
